주요 콘텐츠로 건너뛰기
Reupholstering a Couch Cushion
필요한 것
  1. Reupholstering a Couch Cushion, Couch Upholstery: 1 단계, 이미지 3개 중 1개 Reupholstering a Couch Cushion, Couch Upholstery: 1 단계, 이미지 3개 중 2개 Reupholstering a Couch Cushion, Couch Upholstery: 1 단계, 이미지 3개 중 3개
    • Remove the cushion from the couch. This will easily insure you to get the proper measurements of the cushion.
  2. Reupholstering a Couch Cushion: 2 단계, 이미지 3개 중 1개 Reupholstering a Couch Cushion: 2 단계, 이미지 3개 중 2개 Reupholstering a Couch Cushion: 2 단계, 이미지 3개 중 3개
    • Using a tape measure, measure the height, width, and length the cushion.
  3. Reupholstering a Couch Cushion: 3 단계, 이미지 2개 중 1개 Reupholstering a Couch Cushion: 3 단계, 이미지 2개 중 2개
    • Replace the cushion with a new cushion.
    • In my case, I added a layer of new memory foam on the top and bottom of the existing cushion.
  4. Reupholstering a Couch Cushion: 4 단계, 이미지 1개 중 1개
    • Draw out the measurements on the new fabric.
    • Take the measurements you gathered from Step 2 and measure/draw it on the new fabric to accurately cut the the fabric.
  5. Reupholstering a Couch Cushion: 5 단계, 이미지 2개 중 1개 Reupholstering a Couch Cushion: 5 단계, 이미지 2개 중 2개
    • Cut new fabric along your designated measurement lines.
    • Iron the newly cut fabric to prevent any wrinkles. This will help make for a more smooth and easy process.
  6. Reupholstering a Couch Cushion: 6 단계, 이미지 1개 중 1개
    • Cover the cushion with the fabric
  7. Reupholstering a Couch Cushion: 7 단계, 이미지 2개 중 1개 Reupholstering a Couch Cushion: 7 단계, 이미지 2개 중 2개
    • Staple the fabric onto the cushion so it is secure enough that it will not come loose.
    • Once this step is completed, your cushion is all done and ready to be put back onto your couch!
    • If you would prefer: another way to secure the fabric around the cushion would be the sew it!
  8. Reupholstering a Couch Cushion: 8 단계, 이미지 1개 중 1개
    • Final product!
결론
To reupholster your cushion, follow these instructions:
1. Remove the cushion(s) from the couch.
This will easily insure you to get the proper measurements of the cushion(s).
2. Using a tape measure, measure the height, width, and length of the cushion(s).
3. Replace the cushion with new cushion.
*In my case, I added a layer of new memory foam to the top and bottom of the existing cushion.
4. Draw out the measurements on the new fabric.
5. Cut and iron the new fabric to prevent any wrinkles. *This will help make for a more smooth and easy process.
6. Cover the cushion with the fabric
7. Staple the fabric onto the cushion so it is secure enough that it won’t come loose.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Tiffany St.Lifer
회원 가입일: 01/21/20
187 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 49
전체 시간: 5,086
