소개
The gaskets and seals of this brewing unit are under much strain and have to be replaced from time to time.
The Nivona brewing unit (brewgroup) is identical with those of other brands, such as Bosch, Siemens or Melitta.
필요한 것
Remove the hose connecting the upper piston and the coffee outlet.
Remove the upper piston.
Remove the Torx T20 screw from the screen of the upper piston.
Take off the cover of the gasket and the gasket.
Replace the gaskets of the upper piston, the coffee outlet and water connector.
Clean thoroughly all parts. Use food-proof silicone grease to lubricate the gaskets.
Apply all steps in reverse order to re-assemble the device.
다른 3명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
jana°님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
