주요 콘텐츠로 건너뛰기
Revlon 473 Disassembly
필요한 것
  1. Revlon 473 Disassembly, Shell: 1 단계, 이미지 1/1
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Disassembly: 2 단계, 이미지 1/1
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Disassembly: 3 단계, 이미지 1/3 Revlon 473 Disassembly: 3 단계, 이미지 2/3 Revlon 473 Disassembly: 3 단계, 이미지 3/3
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Disassembly, Revlon 473 Disassembly: 4 단계, 이미지 1/1
    • Take the head of the hairdryer and pull the pieces apart.
  5. Revlon 473 Disassembly: 5 단계, 이미지 1/1
    • Remove the black vent from the grey cylindrical piece.
  6. Revlon 473 Disassembly: 6 단계, 이미지 1/1
    • If there is lint in the vent, use tweezers or a toothbrush to extract it from the vent.
    • This will keep the fan from getting clogged and malfunctioning.
  7. Revlon 473 Disassembly: 7 단계, 이미지 1/2 Revlon 473 Disassembly: 7 단계, 이미지 2/2
    • Clean the other black vent with a toothbrush.
  8. Revlon 473 Disassembly: 8 단계, 이미지 1/1
    • Clean these two components with a paper towel.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jessica Leyva
회원 가입일: 09/18/12
143 평판
안내서 5개 작성하였습니다
Cal Poly, Team 1-5, Propen Fall 2012 Cal Poly, Team 1-5, Propen Fall 2012 회원
CPSU-PROPEN-F12S1G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 14
전체 시간: 1,963
