주요 콘텐츠로 건너뛰기
Revlon 473 Hair Dryer Switch Replacement
필요한 것
  1. Revlon 473 Hair Dryer Switch Replacement, Shell: 1 단계, 이미지 1/1
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Hair Dryer Switch Replacement: 2 단계, 이미지 1/1
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Hair Dryer Switch Replacement: 3 단계, 이미지 1/3 Revlon 473 Hair Dryer Switch Replacement: 3 단계, 이미지 2/3 Revlon 473 Hair Dryer Switch Replacement: 3 단계, 이미지 3/3
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Hair Dryer Switch Replacement, Switch: 4 단계, 이미지 1/1
    • Locate the two switches in the handle of the device.
  5. Revlon 473 Hair Dryer Switch Replacement: 5 단계, 이미지 1/1
    • Set the multimeter to 200 ACV.
  6. Revlon 473 Hair Dryer Switch Replacement: 6 단계, 이미지 1/1
    • Bring the probes toward each switch to test for continuity.
    • If the numbers on the multimeter continue to change, the circuit is closed and the switches are functioning.
    • If the meter stays at a set number, the circuit is open, and the switch needs to be replaced.
    • To replace a faulty switch, cut the wires and solder the wires back on to the new switch.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jessica Leyva
회원 가입일: 09/18/12
143 평판
안내서 5개 작성하였습니다
Cal Poly, Team 1-5, Propen Fall 2012 Cal Poly, Team 1-5, Propen Fall 2012 회원
CPSU-PROPEN-F12S1G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 31
전체 시간: 1,818
