주요 콘텐츠로 건너뛰기
Revlon 473 Heating Element Replacement
필요한 것
  1. Revlon 473 Heating Element Replacement, Shell: 1 단계, 이미지 1/1
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Heating Element Replacement: 2 단계, 이미지 1/1
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Heating Element Replacement: 3 단계, 이미지 1/3 Revlon 473 Heating Element Replacement: 3 단계, 이미지 2/3 Revlon 473 Heating Element Replacement: 3 단계, 이미지 3/3
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Heating Element Replacement, Heating Element: 4 단계, 이미지 1/1
    • The heating element is the group of tightly coiled bronze wires behind the vent hose as well as the silver coils.
    • Make sure that there are no breaks or debris obstructing the wires of the heating element.
  5. Revlon 473 Heating Element Replacement: 5 단계, 이미지 1/1
    • To test the heating element, use a digital multimeter.
    • Set the multimeter to 200 under ACV.
    • Bring the ends of the multimeter toward the two lead wires.
    • If the circuit between the wires is closed, the numbers on the multimeter should keep changing.
    • If the numbers are not changing, replace the heating element.
    • If the circuit is closed, check the thermal cutout.
결론
Jessica Leyva
회원 가입일: 09/18/12
143 평판
안내서 5개 작성하였습니다
Cal Poly, Team 1-5, Propen Fall 2012 Cal Poly, Team 1-5, Propen Fall 2012 회원
CPSU-PROPEN-F12S1G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 14
전체 시간: 1,876
