주요 콘텐츠로 건너뛰기
Revlon 473 Thermal Cutout Replacement
필요한 것
  1. Revlon 473 Thermal Cutout Replacement, Shell: 1 단계, 이미지 1/1
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Thermal Cutout Replacement: 2 단계, 이미지 1/1
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Thermal Cutout Replacement: 3 단계, 이미지 1/3 Revlon 473 Thermal Cutout Replacement: 3 단계, 이미지 2/3 Revlon 473 Thermal Cutout Replacement: 3 단계, 이미지 3/3
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Thermal Cutout Replacement, Thermal Cutout: 4 단계, 이미지 1/1
    • Locate the thermal cutout under the coils of the heating element.
  5. Revlon 473 Thermal Cutout Replacement: 5 단계, 이미지 1/1
    • Test the thermal cutout for continuity using the multimeter.
    • Make sure the multimeter is set to 200 ACV and bring the probes toward the thermal cutout.
    • If the numbers on the multimeter continue to change, the circuit is closed and properly functioning.
    • If the multimeter reads a consistent number, the circuit is opened and the thermal cutout needs to be replaced.
  6. Revlon 473 Thermal Cutout Replacement: 6 단계, 이미지 1/1
    • To replace the thermal cutout, use the spudgers to extract the object.
    • To remove, wedge it back and forth until it comes free.
    • You do not need to take out the gold piece, only the thermal cutout.
  7. Revlon 473 Thermal Cutout Replacement: 7 단계, 이미지 1/1
    • Replace the old thermal cutout with a new thermal cutout by snapping it into place.
결론
Jessica Leyva
회원 가입일: 09/18/12
143 평판
안내서 5개 작성하였습니다
Cal Poly, Team 1-5, Propen Fall 2012 Cal Poly, Team 1-5, Propen Fall 2012 회원
CPSU-PROPEN-F12S1G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 10
전체 시간: 1,866
