주요 콘텐츠로 건너뛰기
Rewriting corrupted firmware on Digitech JamMan Solo
필요한 것
  1. Rewriting corrupted firmware on Digitech JamMan Solo, Check for firmware updates: 1 단계, 이미지 1개 중 1개
    • Before starting, plug your pedal to a computer using an USB mini B cable.
    • If your device is detected (for instance in Peripheral Manager for Windows users, with "lsusb" for Linux users)
    • Install the JamManager software from here
    • Try updating the firmware using JamManager
    • If your device is not detected, or if the firmware update fails, carry on with this tutorial
    • The following procedure is risky and may render your device more definitely bricked than it already was.
  2. Rewriting corrupted firmware on Digitech JamMan Solo, Open the pedal: 2 단계, 이미지 2개 중 1개 Rewriting corrupted firmware on Digitech JamMan Solo, Open the pedal: 2 단계, 이미지 2개 중 2개
    • Unscrew the 4 Torx T15H holding the bottom plate
    • Free the bottom plate
  3. Rewriting corrupted firmware on Digitech JamMan Solo, Lift the board: 3 단계, 이미지 3개 중 1개 Rewriting corrupted firmware on Digitech JamMan Solo, Lift the board: 3 단계, 이미지 3개 중 2개 Rewriting corrupted firmware on Digitech JamMan Solo, Lift the board: 3 단계, 이미지 3개 중 3개
    • Unscrew the 3 jack connectors bolts
    • Lift the board from the top of the pedal
    • Unscrew the 2 Torx T15H holding the SD card
    • The board can be moved out of the pedal
    • There is no need to unmount it further to access the debug port
    • Connectors to the display and button boards and to the SD card slot are soldered, do not try to disconnect them
  4. Rewriting corrupted firmware on Digitech JamMan Solo, Take a look at the board: 4 단계, 이미지 3개 중 1개 Rewriting corrupted firmware on Digitech JamMan Solo, Take a look at the board: 4 단계, 이미지 3개 중 2개 Rewriting corrupted firmware on Digitech JamMan Solo, Take a look at the board: 4 단계, 이미지 3개 중 3개
    • Spot the debug UART port
    • Under the button when looking from the top
    • Marked as "P3" when looking from the bottom
    • UART connection requires to connect TXD, RXD and GND
  5. Rewriting corrupted firmware on Digitech JamMan Solo, Solder debug UART cables: 5 단계, 이미지 2개 중 1개 Rewriting corrupted firmware on Digitech JamMan Solo, Solder debug UART cables: 5 단계, 이미지 2개 중 2개
    • Solder a 3V3 USB-UART adapter to the pins by following this pinout
    • GND connected to the adapter GND
    • TX connected to the adapter RX
    • RX connected to the adapter TX
    • You can also solder an intermediate 2.54mm DuPont-style header connector and use DuPont debug cables
    • No need to connect 3V3, RTS and CTS
    • Connect to the USB-UART adapter using an appropriate software
    • PuTTy on Windows machines
    • Screen or Minicom on Linux machines
    • The serial parameters are: 115200, 2N1, no flow control
    • Once everything is connected, you can plug the 9V power supply to the pedal
    • It should display startup messages
    • Afterwards, it should give you a prompt with the possibility to interact with it
    • Try typing "ls"
    • If possible, ask a friend to do the same with a working pedal
    • On the working pedal, with the USB-UART probe and with an SD Card inserted, type:
    • etfsctl -d /dev/etfs2 -r /mnt/sdfs/etfs2.structured.bin
    • cp -r /mnt/nandfs/* /mnt/sdfs/nandfs_copy
    • Otherwise, recover the files from the Internet
    • My copy of a working JamManSolo firmware
    • Copy them from your computer to the SD card
    • Make sure you have the exact same model, JamMan Solo, do not use for the JamMan Solo HD or any other product!
    • Insert the SD card with the working files in the device and run:
    • etfsctl -d /dev/etfs2 -S -e -w /mnt/sdfs/etfs2.structured.bin -c
    • Once it is done, power cycle the device and checks if it works
    • If it is still missing files, run:
    • cp -r /mnt/sdfs/nandfs_copy/* /mnt/nandfs
    • Power cycle and verifies the device is working
결론
To reassemble your device, unplug it, unsolder the usb-serial adapter, and follow these instructions in reverse order.
작성자
1다른 기여자 명과 함께
Eve Redero
회원 가입일: 02/28/22
3,101 평판
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 7
전체 시간: 65
