주요 콘텐츠로 건너뛰기
Ricoh Super 8 800z Film Cartridge Hooks Replacement
필요한 것
  1. Ricoh Super 8 800z Film Cartridge Hooks Replacement, Film Cartridge Hooks: 1 단계, 이미지 1/3 Ricoh Super 8 800z Film Cartridge Hooks Replacement, Film Cartridge Hooks: 1 단계, 이미지 2/3 Ricoh Super 8 800z Film Cartridge Hooks Replacement, Film Cartridge Hooks: 1 단계, 이미지 3/3
    • Open the device's film cartridge door by pulling the release switch towards the eyepiece.
    • Lay the device with the left side down and the door open to allow access to the film cartridge hooks.
  2. Ricoh Super 8 800z Film Cartridge Hooks Replacement: 2 단계, 이미지 1/3 Ricoh Super 8 800z Film Cartridge Hooks Replacement: 2 단계, 이미지 2/3 Ricoh Super 8 800z Film Cartridge Hooks Replacement: 2 단계, 이미지 3/3
    • Using a Phillips #000 screwdriver, remove one of the screws from the rotating hooks in the center of the film bay.
    • Be sure to hold down the opposite side of the hooks with a finger to prevent it from spinning.
  3. Ricoh Super 8 800z Film Cartridge Hooks Replacement: 3 단계, 이미지 1/2 Ricoh Super 8 800z Film Cartridge Hooks Replacement: 3 단계, 이미지 2/2
    • Now put your finger on the side of the screw you just removed, and take out the remaining screw with a Phillips #000 screwdriver.
  4. Ricoh Super 8 800z Film Cartridge Hooks Replacement: 4 단계, 이미지 1/2 Ricoh Super 8 800z Film Cartridge Hooks Replacement: 4 단계, 이미지 2/2
    • Using your fingers, gently remove the film cartridge hooks.
결론
carlos enrique
회원 가입일: 01/30/20
335 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 222
