주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ricoh Theta S Battery Replacement
필요한 것
    1. Ricoh Theta S Battery Replacement, Outer Case: 1 단계, 이미지 1개 중 1개
      • Wedge the spudger underneath the small plastic square located on the bottom of the device.
      • Move the spudger to remove the plastic cover.
      댓글 쓰기
    2. Ricoh Theta S Battery Replacement: 2 단계, 이미지 2개 중 1개 Ricoh Theta S Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the four 3-mm screws located on the bottom of the device. You will need to use the Phillips 00 screwdriver.
      댓글 쓰기
    3. Ricoh Theta S Battery Replacement: 3 단계, 이미지 3개 중 1개 Ricoh Theta S Battery Replacement: 3 단계, 이미지 3개 중 2개 Ricoh Theta S Battery Replacement: 3 단계, 이미지 3개 중 3개
      • Insert the plastic opening tool in between the panels shown.
      • Apply pressure to unlatch the 9 spring clips located around the perimeter of the device.
      • Lift the panel from the device.
      댓글 쓰기
    1. Ricoh Theta S Battery Replacement, Battery: 4 단계, 이미지 2개 중 1개 Ricoh Theta S Battery Replacement, Battery: 4 단계, 이미지 2개 중 2개
      • The battery is located near the bottom of the device.
      • Flip the plastic containing thermal compound over so it is resting on top of the battery.
      댓글 쓰기
    2. Ricoh Theta S Battery Replacement: 5 단계, 이미지 2개 중 1개 Ricoh Theta S Battery Replacement: 5 단계, 이미지 2개 중 2개
      • Lift the battery out of the device, beginning with the end closest to the camera.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Bradley Sutton
회원 가입일: 11/07/17
866 평판
안내서 4개를 작성함
IUPUI, Team S3-G1, Harley Fall 2017 IUPUI, Team S3-G1, Harley Fall 2017 회원
IUPUI-HARLEY-F17S3G1
3 회원들
안내서 32개를 작성함
9가이드 댓글
Nice demonstration, but if I can’t find a DB-110 replacement battery, I’m not sure if I would take the camera apart. If I find a replacement, this step-by-step demonstration will be very helpful.
Joel Brondos - 답글 공유
The battery replacement for Ricoh Theta S is the Olympus battery model LI-92B.
It’s the perfect equivalent of the original Ricoh DB-110 battery. Tested personally.
Please don’t use any other similar battery or you risk to breaking the charge control circuit of the camera!!
Please note that you nullify the warranty, if the item is under coverage.
Franco - 답글 공유
Do you have a good link for Olympus battery model LI-92B ?
Patrick D - 답글 공유
It its very important to observe to remove the right side of the camera cover ! it is the side without button !!!
wkaemena - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 20
지난 30일: 88
전체 시간: 12,654
