주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ricoh Theta S Internal microSD Replacement
필요한 것
    1. Ricoh Theta S Internal microSD Replacement, Outer Case: 1 단계, 이미지 1개 중 1개
      • Wedge the spudger underneath the small plastic square located on the bottom of the device.
      • Move the spudger to remove the plastic cover.
      댓글 쓰기
    2. Ricoh Theta S Internal microSD Replacement: 2 단계, 이미지 2개 중 1개 Ricoh Theta S Internal microSD Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the four 3-mm screws located on the bottom of the device. You will need to use the Phillips 00 screwdriver.
      댓글 쓰기
    3. Ricoh Theta S Internal microSD Replacement: 3 단계, 이미지 3개 중 1개 Ricoh Theta S Internal microSD Replacement: 3 단계, 이미지 3개 중 2개 Ricoh Theta S Internal microSD Replacement: 3 단계, 이미지 3개 중 3개
      • Insert the plastic opening tool in between the panels shown.
      • Apply pressure to unlatch the 9 spring clips located around the perimeter of the device.
      • Lift the panel from the device.
      댓글 쓰기
    1. Ricoh Theta S Internal microSD Replacement, Battery: 4 단계, 이미지 2개 중 1개 Ricoh Theta S Internal microSD Replacement, Battery: 4 단계, 이미지 2개 중 2개
      • The battery is located near the bottom of the device.
      • Flip the plastic containing thermal compound over so it is resting on top of the battery.
      댓글 쓰기
    2. Ricoh Theta S Internal microSD Replacement: 5 단계, 이미지 2개 중 1개 Ricoh Theta S Internal microSD Replacement: 5 단계, 이미지 2개 중 2개
      • Lift the battery out of the device, beginning with the end closest to the camera.
      댓글 쓰기
    1. Ricoh Theta S Internal microSD Replacement, Internal microSD: 6 단계, 이미지 1개 중 1개
      • Remove the two 2mm Phillips screws.
      • Remove the black 2mm Phillips screw.
      • Remove the 1.5mm Phillips screw.
      댓글 쓰기
    2. Ricoh Theta S Internal microSD Replacement: 7 단계, 이미지 3개 중 1개 Ricoh Theta S Internal microSD Replacement: 7 단계, 이미지 3개 중 2개 Ricoh Theta S Internal microSD Replacement: 7 단계, 이미지 3개 중 3개
      • Carefully pull the side casing away from the camera.
      댓글 쓰기
    3. Ricoh Theta S Internal microSD Replacement: 8 단계, 이미지 3개 중 1개 Ricoh Theta S Internal microSD Replacement: 8 단계, 이미지 3개 중 2개 Ricoh Theta S Internal microSD Replacement: 8 단계, 이미지 3개 중 3개
      • Lift up the plastic containing thermal compound to reveal the thermal tape covering the motherboard.
      • Peel back the lower left corner of the thermal tape to reveal the microSD slot located on the motherboard.
      댓글 쓰기
    4. Ricoh Theta S Internal microSD Replacement: 9 단계, 이미지 2개 중 1개 Ricoh Theta S Internal microSD Replacement: 9 단계, 이미지 2개 중 2개
      • Push the microSD card inward, from the side.
      • Once a click is heard, pull the screwdriver away to eject the microSD card from the slot.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Bradley Sutton
회원 가입일: 11/07/17
866 평판
안내서 4개를 작성함
IUPUI, Team S3-G1, Harley Fall 2017 IUPUI, Team S3-G1, Harley Fall 2017 회원
IUPUI-HARLEY-F17S3G1
3 회원들
안내서 32개를 작성함
8가이드 댓글
I was able to complete this however there is a clear plastic guard running around the bottom half of the Theta S, and the only way to get the SD Card above that guard was to remove a few additional screws. Fortunately was not that complex and reassembly was still successful. Good luck!
jason - 답글 공유
Maximum size of SD Card? 128GB?
just - 답글 공유
I’ve not heard of anyone getting anything over 32gb to work, but I don’t think that’s definitive, as, even with 32GB cards, some would work and some wouldn’t. I think I might order a 64gb and try it out…
Basil Yokarinis - 답글 공유
I successfully replaced my microSD card with a transcend 32gb card, and it’s working. Only thing is, I ended up with 2 tiny braided wire sleeves that fell out during the process, and I have no idea where they are supposed to be. Also, before the repair, I had, an error come up at random and stop interval shooting (while there was still space available and power):
_cameraError":[“FORMAT_CARD”]
Now, after the repair, the error is:
_cameraError":["FORMAT_INTERNAL_MEM"]
And it’s constant, but, aside from causing the red lamp to blink always, and also beeping when I turn it on, it doesn’t seem to affect the function of the camera.
One point to improve the tutorial would be in step 8, in the 3rd picture, there’s a metallic, odd shaped piece sitting at an angle in the picture. This piece fell out when I was working to replace the microSD card, and I had to search other tutorials to figure out where it had to go.
Correction, it was a Sandisk Ultra
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 48
전체 시간: 5,033
