주요 콘텐츠로 건너뛰기
Ricoh Theta S Outer Case Replacement
필요한 것
  1. Ricoh Theta S Outer Case Replacement, Outer Case: 1 단계, 이미지 1/1
    • Wedge the spudger underneath the small plastic square located on the bottom of the device.
    • Move the spudger to remove the plastic cover.
  2. Ricoh Theta S Outer Case Replacement: 2 단계, 이미지 1/2 Ricoh Theta S Outer Case Replacement: 2 단계, 이미지 2/2
    • Remove the four 3-mm screws located on the bottom of the device. You will need to use the Phillips 00 screwdriver.
  3. Ricoh Theta S Outer Case Replacement: 3 단계, 이미지 1/3 Ricoh Theta S Outer Case Replacement: 3 단계, 이미지 2/3 Ricoh Theta S Outer Case Replacement: 3 단계, 이미지 3/3
    • Insert the plastic opening tool in between the panels shown.
    • Apply pressure to unlatch the 9 spring clips located around the perimeter of the device.
    • Lift the panel from the device.
결론
Bradley Sutton
회원 가입일: 11/07/17
737 평판
안내서 4개 작성하였습니다
IUPUI, Team S3-G1, Harley Fall 2017 IUPUI, Team S3-G1, Harley Fall 2017 회원
IUPUI-HARLEY-F17S3G1
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
Where can find spare part case?
Thanks
Franco - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 14
전체 시간: 2,124
