주요 콘텐츠로 건너뛰기
Ricoh Theta S Outer Case Replacement
필요한 것
  1. Ricoh Theta S Outer Case Replacement, Outer Case: 1 단계, 이미지 1/1
    • Wedge the spudger underneath the small plastic square located on the bottom of the device.
    • Move the spudger to remove the plastic cover.
  2. Ricoh Theta S Outer Case Replacement: 2 단계, 이미지 1/2 Ricoh Theta S Outer Case Replacement: 2 단계, 이미지 2/2
    • Remove the four 3-mm screws located on the bottom of the device. You will need to use the Phillips 00 screwdriver.
    when doing this careful as the screws do strip
    david.demian - 답글
  3. Ricoh Theta S Outer Case Replacement: 3 단계, 이미지 1/3 Ricoh Theta S Outer Case Replacement: 3 단계, 이미지 2/3 Ricoh Theta S Outer Case Replacement: 3 단계, 이미지 3/3
    • Insert the plastic opening tool in between the panels shown.
    • Apply pressure to unlatch the 9 spring clips located around the perimeter of the device.
    • Lift the panel from the device.
    thank you for the instructions. Keep in mind that the Spring clips are just on the other side of the phone, the side without the photo button. Then metal casing is attached to the front and can bend easy. So be careful here. If you get a red light, 5 beeps, and the device turns off, it means you’ve got a physical error code, and you need to investigate. In my case, I disconnected one of the flex cables to one of the cameras, and this needed to be redone.
    david.demian - 답글
결론
Bradley Sutton
회원 가입일: 11/07/17
737 평판
안내서 4개 작성하였습니다
IUPUI, Team S3-G1, Harley Fall 2017 IUPUI, Team S3-G1, Harley Fall 2017 회원
IUPUI-HARLEY-F17S3G1
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
Where can find spare part case?
Thanks
Franco - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 2,110
