주요 콘텐츠로 건너뛰기
Ricoh YF-20 Super Button Mechanism Replacement
필요한 것
  1. Ricoh YF-20 Super Button Mechanism Replacement, Front Cover: 1 단계, 이미지 2개 중 1개 Ricoh YF-20 Super Button Mechanism Replacement, Front Cover: 1 단계, 이미지 2개 중 2개
    • Use the screwdriver to unscrew the indicated screws from the left, right, bottom, and back sides of the camera.
  2. Ricoh YF-20 Super Button Mechanism Replacement: 2 단계, 이미지 3개 중 1개 Ricoh YF-20 Super Button Mechanism Replacement: 2 단계, 이미지 3개 중 2개 Ricoh YF-20 Super Button Mechanism Replacement: 2 단계, 이미지 3개 중 3개
    • Loosen the back cover from both the left and the right sides of the camera. Take off the back cover.
    • The lid of the battery compartment may fall off because it is not attached to anything.
  3. Ricoh YF-20 Super Button Mechanism Replacement: 3 단계, 이미지 3개 중 1개 Ricoh YF-20 Super Button Mechanism Replacement: 3 단계, 이미지 3개 중 2개 Ricoh YF-20 Super Button Mechanism Replacement: 3 단계, 이미지 3개 중 3개
    • Open the film compartment.
    • Press your finger on top of the grey latch on the left side of the camera.
  4. Ricoh YF-20 Super Button Mechanism Replacement: 4 단계, 이미지 3개 중 1개 Ricoh YF-20 Super Button Mechanism Replacement: 4 단계, 이미지 3개 중 2개 Ricoh YF-20 Super Button Mechanism Replacement: 4 단계, 이미지 3개 중 3개
    • Removing the film compartment door is optional. However, it may aid maneuverability in future steps.
    • Use a thin object like a toothpick or a small screwdriver to push down on the metal pin holding the film compartment door in place.
    • Use your fingers to completely remove the metal pin.
    • Remove the film compartment door.
  5. Ricoh YF-20 Super Button Mechanism Replacement: 5 단계, 이미지 2개 중 1개 Ricoh YF-20 Super Button Mechanism Replacement: 5 단계, 이미지 2개 중 2개
    • Use a thin shaft screwdriver and unscrew the two indicated screws within the film compartment.
  6. Ricoh YF-20 Super Button Mechanism Replacement: 6 단계, 이미지 3개 중 1개 Ricoh YF-20 Super Button Mechanism Replacement: 6 단계, 이미지 3개 중 2개 Ricoh YF-20 Super Button Mechanism Replacement: 6 단계, 이미지 3개 중 3개
    • Loosen the front cover from the left and right sides of the camera.
    • Take off the front cover.
  7. Ricoh YF-20 Super Button Mechanism Replacement, Buttons: 7 단계, 이미지 3개 중 1개 Ricoh YF-20 Super Button Mechanism Replacement, Buttons: 7 단계, 이미지 3개 중 2개 Ricoh YF-20 Super Button Mechanism Replacement, Buttons: 7 단계, 이미지 3개 중 3개
    • Remove and set the front and back covers aside
    • Unscrew the screw that holds the front plate brace in place.
    • Take out the brace.
  8. Ricoh YF-20 Super Button Mechanism Replacement: 8 단계, 이미지 3개 중 1개 Ricoh YF-20 Super Button Mechanism Replacement: 8 단계, 이미지 3개 중 2개 Ricoh YF-20 Super Button Mechanism Replacement: 8 단계, 이미지 3개 중 3개
    • Unscrew the four screws keeping the front face plate in place.
    • The top left screw also holds a metal clip in place.
    • Remove metal clip.
  9. Ricoh YF-20 Super Button Mechanism Replacement: 9 단계, 이미지 3개 중 1개 Ricoh YF-20 Super Button Mechanism Replacement: 9 단계, 이미지 3개 중 2개 Ricoh YF-20 Super Button Mechanism Replacement: 9 단계, 이미지 3개 중 3개
    • After removing the metal clip in the previous step, the front face plate can be removed.
    • The front face plate is attached to the camera body by two small wires. Carefully remove the plate and completely separate it from the camera body.
  10. Ricoh YF-20 Super Button Mechanism Replacement: 10 단계, 이미지 3개 중 1개 Ricoh YF-20 Super Button Mechanism Replacement: 10 단계, 이미지 3개 중 2개 Ricoh YF-20 Super Button Mechanism Replacement: 10 단계, 이미지 3개 중 3개
    • Unscrew the two screws that hold the button mechanism in place.
    • Press down on button mechanism to unlatch it from the camera body. When pressed down, the bottom of the mechanism should push outward.
  11. Ricoh YF-20 Super Button Mechanism Replacement: 11 단계, 이미지 3개 중 1개 Ricoh YF-20 Super Button Mechanism Replacement: 11 단계, 이미지 3개 중 2개 Ricoh YF-20 Super Button Mechanism Replacement: 11 단계, 이미지 3개 중 3개
    • Lift the button mechanism up carefully, removing the spring at the top of the mechanism from where it is attached to the camera body.
    • Take out the button mechanism.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
작성자
10다른 기여자 명과 함께
Eric Dazet
회원 가입일: 04/10/12
352 평판
안내서 5개를 작성함
Cal Poly, Team 6-21, Amido Spring 2012 Cal Poly, Team 6-21, Amido Spring 2012 회원
CPSU-AMIDO-S12S6G21
4 회원들
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 27
전체 시간: 1,446
