주요 콘텐츠로 건너뛰기
Ricoh YF-20 Super Lens Cover Replacement
필요한 것
  1. Ricoh YF-20 Super Lens Cover Replacement, Front Cover: 1 단계, 이미지 1/2 Ricoh YF-20 Super Lens Cover Replacement, Front Cover: 1 단계, 이미지 2/2
    • Use the screwdriver to unscrew the indicated screws from the left, right, bottom, and back sides of the camera.
  2. Ricoh YF-20 Super Lens Cover Replacement: 2 단계, 이미지 1/3 Ricoh YF-20 Super Lens Cover Replacement: 2 단계, 이미지 2/3 Ricoh YF-20 Super Lens Cover Replacement: 2 단계, 이미지 3/3
    • Loosen the back cover from both the left and the right sides of the camera. Take off the back cover.
    • The lid of the battery compartment may fall off because it is not attached to anything.
  3. Ricoh YF-20 Super Lens Cover Replacement: 3 단계, 이미지 1/3 Ricoh YF-20 Super Lens Cover Replacement: 3 단계, 이미지 2/3 Ricoh YF-20 Super Lens Cover Replacement: 3 단계, 이미지 3/3
    • Open the film compartment.
    • Press your finger on top of the grey latch on the left side of the camera.
  4. Ricoh YF-20 Super Lens Cover Replacement: 4 단계, 이미지 1/3 Ricoh YF-20 Super Lens Cover Replacement: 4 단계, 이미지 2/3 Ricoh YF-20 Super Lens Cover Replacement: 4 단계, 이미지 3/3
    • Removing the film compartment door is optional. However, it may aid maneuverability in future steps.
    • Use a thin object like a toothpick or a small screwdriver to push down on the metal pin holding the film compartment door in place.
    • Use your fingers to completely remove the metal pin.
    • Remove the film compartment door.
  5. Ricoh YF-20 Super Lens Cover Replacement: 5 단계, 이미지 1/2 Ricoh YF-20 Super Lens Cover Replacement: 5 단계, 이미지 2/2
    • Use a thin shaft screwdriver and unscrew the two indicated screws within the film compartment.
  6. Ricoh YF-20 Super Lens Cover Replacement: 6 단계, 이미지 1/3 Ricoh YF-20 Super Lens Cover Replacement: 6 단계, 이미지 2/3 Ricoh YF-20 Super Lens Cover Replacement: 6 단계, 이미지 3/3
    • Loosen the front cover from the left and right sides of the camera.
    • Take off the front cover.
  7. Ricoh YF-20 Super Lens Cover Replacement, Lens Cover: 7 단계, 이미지 1/3 Ricoh YF-20 Super Lens Cover Replacement, Lens Cover: 7 단계, 이미지 2/3 Ricoh YF-20 Super Lens Cover Replacement, Lens Cover: 7 단계, 이미지 3/3
    • The lens cover is only attached to the front cover of the camera. Set the rest of the camera aside.
    • In order to reach the lens cover, the zoom mechanism must be removed.
    • Unscrew three screws from the front cover that hold the zoom mechanism in place.
    • Remove the zoom mechanism.
  8. Ricoh YF-20 Super Lens Cover Replacement: 8 단계, 이미지 1/3 Ricoh YF-20 Super Lens Cover Replacement: 8 단계, 이미지 2/3 Ricoh YF-20 Super Lens Cover Replacement: 8 단계, 이미지 3/3
    • Unscrew the five screws that hold the lens cover plate and metal brace in place.
    • Remove metal brace.
    • Remove lens cover plate.
  9. Ricoh YF-20 Super Lens Cover Replacement: 9 단계, 이미지 1/2 Ricoh YF-20 Super Lens Cover Replacement: 9 단계, 이미지 2/2
    • To remove lens cover, push the lens cover from the outside of the front cover towards the inside of the front cover.
    • Remove the lens cover.
    • The metal arm attached to the lens cover is not securely attached and may fall off.
결론
Eric Dazet
회원 가입일: 04/10/12
352 평판
안내서 5개 작성하였습니다
Cal Poly, Team 6-21, Amido Spring 2012 Cal Poly, Team 6-21, Amido Spring 2012 회원
CPSU-AMIDO-S12S6G21
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 311
