이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
If the helmet has a visor remove this from the facemask first.
Visors are typically attached by screws to the facemask itself, although different models have different attachment systems.
Using the Riddell Quick Release tool (or a suitable alternative) press the center button of the quick release fastener to unlock the attachment.
Unscrew the top two attachments with a screw driver at the top of the facemask.
Slip off the four plastic clips and attach them onto the same spots on the new facemask.
Prepare to reattach the quick release attachments on the sides of the helmet by inserting the top releasing mechanism into the plastic fastener and aligning the back washer on the inside of the helmet.
Simply use your fingers to press together the back and front of the quick release attachments to lock them into place.
Lastly, if necessary reattach the visor.
If there is no visor to reattach, then the helmet is completed.
다른 2명이 해당 안내서를 완성하였습니다.
