주요 콘텐츠로 건너뛰기
Ridgid Angle Grinder R10202 Motor Housing Replacement
필요한 것
  1. Ridgid Angle Grinder R10202 Motor Housing Replacement, Carbon Brush: 1 단계, 이미지 1/2 Ridgid Angle Grinder R10202 Motor Housing Replacement, Carbon Brush: 1 단계, 이미지 2/2
    • Use a flathead screwdriver to unscrew the brush holder cap.
  2. Ridgid Angle Grinder R10202 Motor Housing Replacement: 2 단계, 이미지 1/2 Ridgid Angle Grinder R10202 Motor Housing Replacement: 2 단계, 이미지 2/2
    • Using your fingers, gently lift the carbon brush up and out of its housing.
    • Repeat these steps to remove the other carbon brush on the opposing side.
  3. Ridgid Angle Grinder R10202 Motor Housing Replacement, Motor Housing: 3 단계, 이미지 1/1
    • Unscrew the side handle assembly from the gear housing assembly by hand.
  4. Ridgid Angle Grinder R10202 Motor Housing Replacement: 4 단계, 이미지 1/1
    • Unscrew the clamp nut and the backing flange from the output shaft assembly.
    • You can do this by hand or use a spanner wrench which should be provided in the manufacturers box.
  5. Ridgid Angle Grinder R10202 Motor Housing Replacement: 5 단계, 이미지 1/2 Ridgid Angle Grinder R10202 Motor Housing Replacement: 5 단계, 이미지 2/2
    • Push in the guard lever and twist the guard until it aligns with the slots on the output shaft assembly.
    • There are two arrows that should align before you attempt to pull the pieces apart.
  6. Ridgid Angle Grinder R10202 Motor Housing Replacement: 6 단계, 이미지 1/1
    • Lift the guard away from the output shaft assembly.
  7. Ridgid Angle Grinder R10202 Motor Housing Replacement: 7 단계, 이미지 1/2 Ridgid Angle Grinder R10202 Motor Housing Replacement: 7 단계, 이미지 2/2
    • Using a T25 Torx screwdriver, unscrew the four M5 X 28mm Torx screws.
  8. Ridgid Angle Grinder R10202 Motor Housing Replacement: 8 단계, 이미지 1/3 Ridgid Angle Grinder R10202 Motor Housing Replacement: 8 단계, 이미지 2/3 Ridgid Angle Grinder R10202 Motor Housing Replacement: 8 단계, 이미지 3/3
    • Grab the handle assembly and the gear housing assembly and gently pull apart.
    • Slowly pull the gear housing assembly out being careful not to damage the motor against the inside of the motor housing.
결론
Parker Massie
회원 가입일: 01/10/19
607 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 19
전체 시간: 840
