주요 콘텐츠로 건너뛰기
Ridgid Angle Grinder R10202 Power Trigger Replacement
필요한 것
  1. Ridgid Angle Grinder R10202 Power Trigger Replacement, Ridgid Angle Grinder R10202 Handle Disassembly: 1 단계, 이미지 1/3 Ridgid Angle Grinder R10202 Power Trigger Replacement, Ridgid Angle Grinder R10202 Handle Disassembly: 1 단계, 이미지 2/3 Ridgid Angle Grinder R10202 Power Trigger Replacement, Ridgid Angle Grinder R10202 Handle Disassembly: 1 단계, 이미지 3/3
    • Using a Torx T20 screwdriver, unscrew the five M5 x 16 mm screws.
    • Using the T20 screwdriver, remove the M5 x 28 mm screw.
  2. Ridgid Angle Grinder R10202 Power Trigger Replacement: 2 단계, 이미지 1/1
    • Using a Torx T10 screwdriver, remove the M3 x 10mm screw.
  3. Ridgid Angle Grinder R10202 Power Trigger Replacement: 3 단계, 이미지 1/2 Ridgid Angle Grinder R10202 Power Trigger Replacement: 3 단계, 이미지 2/2
    • Gently pull off the right side handle.
  4. Ridgid Angle Grinder R10202 Power Trigger Replacement: 4 단계, 이미지 1/3 Ridgid Angle Grinder R10202 Power Trigger Replacement: 4 단계, 이미지 2/3 Ridgid Angle Grinder R10202 Power Trigger Replacement: 4 단계, 이미지 3/3
    • Using a hex head screwdriver, remove the two 8-16 x 1/2in screws.
  5. Ridgid Angle Grinder R10202 Power Trigger Replacement: 5 단계, 이미지 1/1
    • Gently pull away the bend relief.
  6. Ridgid Angle Grinder R10202 Power Trigger Replacement: 6 단계, 이미지 1/2 Ridgid Angle Grinder R10202 Power Trigger Replacement: 6 단계, 이미지 2/2
    • Remove the one M4 x 14 mm screw using a Phillips screwdriver.
  7. Ridgid Angle Grinder R10202 Power Trigger Replacement: 7 단계, 이미지 1/1
    • Gently lift away the switch and wires.
  8. Ridgid Angle Grinder R10202 Power Trigger Replacement: 8 단계, 이미지 1/2 Ridgid Angle Grinder R10202 Power Trigger Replacement: 8 단계, 이미지 2/2
    • Press down the handle lock button.
    • Force-ably twist and pull away the left side handle assembly.
  9. Ridgid Angle Grinder R10202 Power Trigger Replacement, Power Trigger: 9 단계, 이미지 1/3 Ridgid Angle Grinder R10202 Power Trigger Replacement, Power Trigger: 9 단계, 이미지 2/3 Ridgid Angle Grinder R10202 Power Trigger Replacement, Power Trigger: 9 단계, 이미지 3/3
    • Using a bit driver, carefully remove the 4 M3.5 X 7mm holding the wires on.
    • Remember the order and position of each wire.
  10. Ridgid Angle Grinder R10202 Power Trigger Replacement: 10 단계, 이미지 1/1
    • The Switch is now free of the Grinder. Dispose of the broken Switch and install your new Switch.
결론
Alexander Armstrong
회원 가입일: 01/10/19
85 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 440
