주요 콘텐츠로 건너뛰기
Ridgid Circular Saw R3205 Lower Blade Guard Replacement
필요한 것
  1. Ridgid Circular Saw R3205 Lower Blade Guard Replacement, Blade: 1 단계, 이미지 1/2 Ridgid Circular Saw R3205 Lower Blade Guard Replacement, Blade: 1 단계, 이미지 2/2
    • Press the black spindle lock and hold it down.
    • While keeping the spindle lock pressed down use a 6mm allen wrench to remove the 5/16-18 x 0.55 inch screw.
  2. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: 2 단계, 이미지 1/1
    • Release the spindle lock and remove the outer flange by lifting it off the output shaft.
  3. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: 3 단계, 이미지 1/3 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: 3 단계, 이미지 2/3 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: 3 단계, 이미지 3/3
    • With the outer flange removed retract the lower blade guard into the upper blade guard housing by pushing on the black lever.
    • Slide the blade out of from the bottom of the saw.
  4. Ridgid Circular Saw R3205 Lower Blade Guard Replacement, Lower Blade Guard: 4 단계, 이미지 1/2 Ridgid Circular Saw R3205 Lower Blade Guard Replacement, Lower Blade Guard: 4 단계, 이미지 2/2
    • Use a prying tool or your fingers to remove the inner flange.
  5. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: 5 단계, 이미지 1/3 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: 5 단계, 이미지 2/3 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: 5 단계, 이미지 3/3
    • Remove the external retaining ring with a screwdriver by expanding it and then prying it out.
  6. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: 6 단계, 이미지 1/1
    • After removing the external retaining ring, remove (OD50 x ID42 x 0.8t) washer.
  7. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: 7 단계, 이미지 1/2 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: 7 단계, 이미지 2/2
    • Remove the lower blade guard after removing the washer.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Joshua Caron
회원 가입일: 04/05/19
792 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S5-G2, Julie Spring 2019 UMass Dartmouth, Team S5-G2, Julie Spring 2019 회원
UMASSD-JULIE-S19S5G2
5 회원들
안내서 5개 작성하였습니다
댓글 한 개
Thank you so VERY much! I was stuck and this was perfectly described!
Chris Bishop - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 26
전체 시간: 2,020
