주요 콘텐츠로 건너뛰기
Ridgid GEN5X R8611506 Outer Case Replacement
필요한 것
  1. Ridgid GEN5X R8611506 Outer Case Replacement, Outer Case: 1 단계, 이미지 1/2 Ridgid GEN5X R8611506 Outer Case Replacement, Outer Case: 1 단계, 이미지 2/2
    • Orient the drill to have the side with the screws facing up.
    • Using the Torx T10 screwdriver, remove the eight 4.0mm screws from the face of the drill.
  2. Ridgid GEN5X R8611506 Outer Case Replacement: 2 단계, 이미지 1/3 Ridgid GEN5X R8611506 Outer Case Replacement: 2 단계, 이미지 2/3 Ridgid GEN5X R8611506 Outer Case Replacement: 2 단계, 이미지 3/3
    • Orient the drill to where the back is facing up.
    • Using a Torx T10 screwdriver, remove the four 6.0mm screws that attach the back piece to the drill.
    • Remove the back piece of the drill using the iFixit opening tool.
  3. Ridgid GEN5X R8611506 Outer Case Replacement: 3 단계, 이미지 1/2 Ridgid GEN5X R8611506 Outer Case Replacement: 3 단계, 이미지 2/2
    • Orient the drill to where the chuck is facing up.
    • Using the Torx T15 screwdriver, remove the four 8.0mm screws from the front of the drill.
  4. Ridgid GEN5X R8611506 Outer Case Replacement: 4 단계, 이미지 1/2 Ridgid GEN5X R8611506 Outer Case Replacement: 4 단계, 이미지 2/2
    • Orient the drill so the side with the screw holes is facing up.
    • Use a plastic opening tool to gently pry the face off of the drill.
    • Remove the face completely from the drill.
결론
Harrison Essary
회원 가입일: 02/05/19
611 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 237
