소개
Use this guide to remove or replace the speed selector switch for the brush-less drill, be sure to distinguish whether the problem stems from a jammed selector switch or one that is not latching to metal wire.
필요한 것
Orient the drill to have the side with the screws facing up.
Using the Torx T10 screwdriver, remove the eight 4.0mm screws from the face of the drill.
Locate the selector switch.
Unhook the selector switch from the small silver wire located near the top of the drill.
거의 끝나갑니다!
결론
