주요 콘텐츠로 건너뛰기
Ridgid GEN5X R8642 Battery Port Replacement
필요한 것
  1. Ridgid GEN5X R8642 Battery Port Replacement, Battery Port: 1 단계, 이미지 1개 중 1개
    • Remove the plastic tab holding the handle cover in place by prying upward with the spudger until the tab pops off.
  2. Ridgid GEN5X R8642 Battery Port Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the handle cover by pulling it towards the front of the saw.
    • The grip can sometimes become stuck and may require a decent amount of force to remove.
  3. Ridgid GEN5X R8642 Battery Port Replacement: 3 단계, 이미지 3개 중 1개 Ridgid GEN5X R8642 Battery Port Replacement: 3 단계, 이미지 3개 중 2개 Ridgid GEN5X R8642 Battery Port Replacement: 3 단계, 이미지 3개 중 3개
    • Use a T20 Torx screwdriver to remove the nine M4 X 16mm screws from the plastic housing.
  4. Ridgid GEN5X R8642 Battery Port Replacement: 4 단계, 이미지 1개 중 1개
    • Use a JIS #1 screwdriver to remove the two M4 x 25mm screws on both sides of the metal housing.
  5. Ridgid GEN5X R8642 Battery Port Replacement: 5 단계, 이미지 1개 중 1개
    • Remove one half of the plastic housing using a spudger so that the internal system is exposed.
  6. Ridgid GEN5X R8642 Battery Port Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the plastic wire covers to the red and black connections on the switch assembly.
    • When you remove the wire covers, you should be able to see the solder on the wires.
    • Desolder the connections on both the red and black wire using a soldering iron.
    • Once the solder is removed, pull out the wires with the battery port attached to the wires.
결론
작성자
4다른 기여자 명과 함께
Grant White
회원 가입일: 02/12/19
453 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 561
