주요 콘텐츠로 건너뛰기
Ridgid GEN5X R8642 Gear Assembly Replacement
필요한 것
  1. Ridgid GEN5X R8642 Gear Assembly Replacement, Gear Assembly: 1 단계, 이미지 1개 중 1개
    • Remove the plastic tab holding the handle cover in place by prying upward with the spudger until the tab pops off.
  2. Ridgid GEN5X R8642 Gear Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the handle cover by pulling it towards the front of the saw.
    • The grip can sometimes become stuck and may require a decent amount of force to remove.
  3. Ridgid GEN5X R8642 Gear Assembly Replacement: 3 단계, 이미지 2개 중 1개 Ridgid GEN5X R8642 Gear Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Use a T20 Torx screwdriver to remove the nine M4 X 16mm screws from the plastic housing.
  4. Ridgid GEN5X R8642 Gear Assembly Replacement: 4 단계, 이미지 1개 중 1개
    • Use a JIS #1 screwdriver to remove the two M4 x 25mm screws on both sides of the metal housing.
  5. Ridgid GEN5X R8642 Gear Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Remove one half of the plastic housing using a spudger so that the internal system is exposed.
  6. Ridgid GEN5X R8642 Gear Assembly Replacement: 6 단계, 이미지 2개 중 1개 Ridgid GEN5X R8642 Gear Assembly Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the one 16mm T20 screw that holds the grip support onto the saw.
  7. Ridgid GEN5X R8642 Gear Assembly Replacement: 7 단계, 이미지 3개 중 1개 Ridgid GEN5X R8642 Gear Assembly Replacement: 7 단계, 이미지 3개 중 2개 Ridgid GEN5X R8642 Gear Assembly Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the five T20 Torx screws from the gear assembly cover and pull the cover off.
  8. Ridgid GEN5X R8642 Gear Assembly Replacement: 8 단계, 이미지 2개 중 1개 Ridgid GEN5X R8642 Gear Assembly Replacement: 8 단계, 이미지 2개 중 2개
    • Carefully remove the motor making sure not to harm any of the wires that are attached. Place motor gently out of the way.
  9. Ridgid GEN5X R8642 Gear Assembly Replacement: 9 단계, 이미지 3개 중 1개 Ridgid GEN5X R8642 Gear Assembly Replacement: 9 단계, 이미지 3개 중 2개 Ridgid GEN5X R8642 Gear Assembly Replacement: 9 단계, 이미지 3개 중 3개
    • Remove the orbital switch by pulling straight up on it.
    • Be careful to not lose the spring and pin that is inside of the switch.
  10. Ridgid GEN5X R8642 Gear Assembly Replacement: 10 단계, 이미지 3개 중 1개 Ridgid GEN5X R8642 Gear Assembly Replacement: 10 단계, 이미지 3개 중 2개 Ridgid GEN5X R8642 Gear Assembly Replacement: 10 단계, 이미지 3개 중 3개
    • Remove the gear assembly by pulling it straight up.
  11. Ridgid GEN5X R8642 Gear Assembly Replacement: 11 단계, 이미지 3개 중 1개 Ridgid GEN5X R8642 Gear Assembly Replacement: 11 단계, 이미지 3개 중 2개 Ridgid GEN5X R8642 Gear Assembly Replacement: 11 단계, 이미지 3개 중 3개
    • Pull the pin holding the metal guide housing in place.
    • Slide the metal guide housing back off the gear assembly.
  12. Ridgid GEN5X R8642 Gear Assembly Replacement: 12 단계, 이미지 2개 중 1개 Ridgid GEN5X R8642 Gear Assembly Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the guide bushing by pulling up on it.
    • Then slide the pin out that holds the gear assembly and blade clamp assembly.
  13. Ridgid GEN5X R8642 Gear Assembly Replacement: 13 단계, 이미지 1개 중 1개
    • Slide the blade clamp assembly off the gear assembly.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Josh Wagoner
회원 가입일: 02/12/19
217 평판
안내서 1개를 작성함
3가이드 댓글
When reassembling with new gear, does gear needs to be greased?
Syoma Zv - 답글
When reassembling after disassembly, cleaning gear case and all parts, how much is the right amount of grease for this gear box.
R Bulley - 답글
Can anyone tell me how much grease to put in the gear case of a Ridgid R8642 Reciprocating saw when gear case is empty and clean.
R Bulley - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 40
전체 시간: 2,482
