주요 콘텐츠로 건너뛰기
Ridgid GEN5X R8653 Base Assembly Replacement
필요한 것
  1. Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: 1 단계, 이미지 1/3 Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: 1 단계, 이미지 2/3 Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: 1 단계, 이미지 3/3
    • Always disconnect battery and use gloves when working with the saw blade. Failure to do so may result in damage or injury!
    • Remove the supplied Allen wrench from it's nesting space in the front of the handle.
    • Depress and hold the spindle lock button located between the handle and blade shroud.
    • Using the supplied 6mm Allen Wrench, unscrew the bolt securing the blade and remove the blade.
  2. Ridgid GEN5X R8653 Base Assembly Replacement: 2 단계, 이미지 1/3 Ridgid GEN5X R8653 Base Assembly Replacement: 2 단계, 이미지 2/3 Ridgid GEN5X R8653 Base Assembly Replacement: 2 단계, 이미지 3/3
    • Remove seven 6mm T20 Torx screws located around base of saw.
    • Pull base assembly away from saw.
    • These screws are very tight and need significant force to be removed.
결론
Andrew Burke
회원 가입일: 09/18/19
663 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 215
