소개
This guide is for a motor repair on the Ridgid JobMax R2851 Series B. This guide would be helpful if you have been noticing slowing motor speeds when using your device or if your device has stopped turning completely and you suspect that you need to do a full motor replacement.
This repair requires minimal tools listed in the guide, and can be done in a short amount of time. Additionally you should remember to unplug your device before starting any repairs to avoid risk of being electrocuted.
필요한 것
Orient the device so that the trigger is facing downwards.
Place your thumb and index finger on the two buttons located on the head of the tool.
Press the two buttons in and pull the head of the tool off.
다른 2명이 해당 안내서를 완성하였습니다.
