소개
The Drive Gear Cover for the Ridgid JobMax R8620 Series E is a crucial part of the device because it allows you to have control. If it is not working properly, please view this guide to see how to replace it.
필요한 것
Pull the battery out of the case by hand before opening the device.
Using a Torx T10 screwdriver, remove the nine 6mm screws on the drill cover.
Lift off the outer casing.
다른 한 분이 해당 안내서를 완성하였습니다.
