주요 콘텐츠로 건너뛰기
Ridgid JobMax R8620 Series E Drive Gear Cover Replacement
필요한 것
  1. Ridgid JobMax R8620 Series E Drive Gear Cover Replacement, Drive Gear Cover: 1 단계, 이미지 1/1
    • Pull the battery out of the case by hand before opening the device.
    • Using a Torx T10 screwdriver, remove the nine 6mm screws on the drill cover.
    • Lift off the outer casing.
  2. Ridgid JobMax R8620 Series E Drive Gear Cover Replacement: 2 단계, 이미지 1/1
    • After opening the cover, find the motor and pry it apart from the case in order to have space to do the replacement.
  3. Ridgid JobMax R8620 Series E Drive Gear Cover Replacement: 3 단계, 이미지 1/3 Ridgid JobMax R8620 Series E Drive Gear Cover Replacement: 3 단계, 이미지 2/3 Ridgid JobMax R8620 Series E Drive Gear Cover Replacement: 3 단계, 이미지 3/3
    • Find the gear cover.
    • Using a Phillips #0 screwdriver, remove the two screws on the plastic protective plate.
    • Remove the plastic plate.
  4. Ridgid JobMax R8620 Series E Drive Gear Cover Replacement: 4 단계, 이미지 1/2 Ridgid JobMax R8620 Series E Drive Gear Cover Replacement: 4 단계, 이미지 2/2
    • Carefully pull off the gear cover.
결론
Pengjian Zhou
회원 가입일: 02/06/19
533 평판
안내서 4개 작성하였습니다
UC Davis, Team S20-G1, Lore Winter 2019 UC Davis, Team S20-G1, Lore Winter 2019 회원
UCD-LORE-W19S20G1
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 11
전체 시간: 713
