주요 콘텐츠로 건너뛰기
Ridgid JobMax R8620 Series E LED Grip Light Replacement
필요한 것
  1. Ridgid JobMax R8620 Series E LED Grip Light Replacement, LED Light: 1 단계, 이미지 1/1
    • Pull the battery out of the case by hand before opening the device.
    • Using a Torx T10 screwdriver, remove the nine 6mm screws on the drill cover.
    • Lift off the outer casing.
  2. Ridgid JobMax R8620 Series E LED Grip Light Replacement: 2 단계, 이미지 1/2 Ridgid JobMax R8620 Series E LED Grip Light Replacement: 2 단계, 이미지 2/2
    • Using a spudger or your fingers, remove the LED light from the groove in the handle.
  3. Ridgid JobMax R8620 Series E LED Grip Light Replacement: 3 단계, 이미지 1/2 Ridgid JobMax R8620 Series E LED Grip Light Replacement: 3 단계, 이미지 2/2
    • Carefully remove the motor as well as the main board from the drill cover.
  4. Ridgid JobMax R8620 Series E LED Grip Light Replacement: 4 단계, 이미지 1/2 Ridgid JobMax R8620 Series E LED Grip Light Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Find the corresponding position of the LED line on the motherboard. If necessary, use tweezers to pull it out and replace it.
결론
Pengjian Zhou
회원 가입일: 02/06/19
557 평판
안내서 4개 작성하였습니다
UC Davis, Team S20-G1, Lore Winter 2019 UC Davis, Team S20-G1, Lore Winter 2019 회원
UCD-LORE-W19S20G1
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 207
