주요 콘텐츠로 건너뛰기
Ridgid R2611 Switch Bracket Replacement
필요한 것
  1. Ridgid R2611 Switch Bracket Replacement, Switch Bracket: 1 단계, 이미지 1/1
    • Remove the seven 2.5 mm screws on the top of the sander using the Torx T15 screwdriver.
  2. Ridgid R2611 Switch Bracket Replacement: 2 단계, 이미지 1/1
    • Remove the top of the sander and put to the side.
  3. Ridgid R2611 Switch Bracket Replacement: 3 단계, 이미지 1/1
    • Use the screwdriver to unscrew the two #6-19 X 5/8 in screws holding down the outlet cord.
  4. Ridgid R2611 Switch Bracket Replacement: 4 단계, 이미지 1/1
    • Remove the cord from the handle.
  5. Ridgid R2611 Switch Bracket Replacement: 5 단계, 이미지 1/1
    • Remove the outer plastic piece holding down the white and black wires.
  6. Ridgid R2611 Switch Bracket Replacement: 6 단계, 이미지 1/1
    • Unplug the two connecting pieces that hold wires.
  7. Ridgid R2611 Switch Bracket Replacement: 7 단계, 이미지 1/1
    • Using the screwdrivers, unscrew the four #6-19 X 5/8 in screws on rectangular block.
  8. Ridgid R2611 Switch Bracket Replacement: 8 단계, 이미지 1/1
    • Remove the black and white wires by pulling out.
  9. Ridgid R2611 Switch Bracket Replacement: 9 단계, 이미지 1/1
    • Put the screwdriver in the holes to release remaining two wires.
  10. Ridgid R2611 Switch Bracket Replacement: 10 단계, 이미지 1/1
    • Remove the two remaining wires from switch, leaving the switch freed.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Ana
회원 가입일: 01/16/19
384 평판
안내서 1개 작성함
University of Alabama, Team S2-G4, Bedsole Spring 2019 University of Alabama, Team S2-G4, Bedsole Spring 2019 회원
UA-BEDSOLE-S19S2G4
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 12
전체 시간: 280
