소개
The Work Piece Contact Assembly is critical to proper function of the nail gun and is composed of several parts that each can fail and require the entire assembly to be disassembled and replace to restore proper function.
Make sure to have a 5/32" Allen wrench.
필요한 것
Remove the single 25 mm hex screw that secures the workpiece contact cover with a 5/32" Allen wrench.
Remove the single 14 mm hex screw that secures the magazine to the lower handle with a 5/32" Allen wrench
Release the depth adjustment knob by rotating it counterclockwise.
Remove the workpiece contact by pulling it parallel to the device.
다른 2명이 해당 안내서를 완성하였습니다.
