주요 콘텐츠로 건너뛰기
Ridgid R82005 2 Speed Gear Train Replacement
필요한 것
  1. Ridgid R82005  2 Speed Gear Train  Replacement, Housing Assembly: 1 단계, 이미지 1/1
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
  2. Ridgid R82005  2 Speed Gear Train  Replacement: 2 단계, 이미지 1/1
    • Push the metallic Housing Connecting clip out with flat side of the plastic opening tool.
    • Eject battery before attempting this step.
  3. Ridgid R82005  2 Speed Gear Train  Replacement: 3 단계, 이미지 1/2 Ridgid R82005  2 Speed Gear Train  Replacement: 3 단계, 이미지 2/2
    • Remove the top half of the Housing Assembly.
  4. Ridgid R82005  2 Speed Gear Train  Replacement: 4 단계, 이미지 1/2 Ridgid R82005  2 Speed Gear Train  Replacement: 4 단계, 이미지 2/2
    • Grasp carefully the top and bottom of drill components.
    • LED light needs to be manually removed.
    • Lift and transfer, as a whole, the drill components from the old housing assembly to the new housing.
    • Make sure all drill components fit properly in the grooves of new Housing Assembly.
  5. Ridgid R82005  2 Speed Gear Train  Replacement, 2 Speed Gear Train: 5 단계, 이미지 1/2 Ridgid R82005  2 Speed Gear Train  Replacement, 2 Speed Gear Train: 5 단계, 이미지 2/2
    • Remove the 2 speed gear selector by carefully lifting it out of the housing, making sure it is free from the speed switch rail.
    • The 2 speed gear selector may fall out on its own.
    • When reassembling, make sure all drill components fit properly in the grooves of the Housing Assembly.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Andrew McPherson
회원 가입일: 02/14/19
479 평판
안내서 3개 작성하였습니다
USF Tampa, Team S1-G2, Leahy Spring 2019 USF Tampa, Team S1-G2, Leahy Spring 2019 회원
USFT-LEAHY-S19S1G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 14
전체 시간: 496
