주요 콘텐츠로 건너뛰기
Ridgid R82005 Housing Assembly Replacement
필요한 것
  1. Ridgid R82005 Housing Assembly  Replacement, Housing Assembly: 1 단계, 이미지 1/1
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
  2. Ridgid R82005 Housing Assembly  Replacement: 2 단계, 이미지 1/1
    • Push the metallic Housing Connecting clip out with flat side of the plastic opening tool.
    • Eject battery before attempting this step.
  3. Ridgid R82005 Housing Assembly  Replacement: 3 단계, 이미지 1/2 Ridgid R82005 Housing Assembly  Replacement: 3 단계, 이미지 2/2
    • Remove the top half of the Housing Assembly.
  4. Ridgid R82005 Housing Assembly  Replacement: 4 단계, 이미지 1/2 Ridgid R82005 Housing Assembly  Replacement: 4 단계, 이미지 2/2
    • Grasp carefully the top and bottom of drill components.
    • LED light needs to be manually removed.
    • Lift and transfer, as a whole, the drill components from the old housing assembly to the new housing.
    • Make sure all drill components fit properly in the grooves of new Housing Assembly.
결론
To reassemble your device, follow these instructions in reverse order. Also reinsert the battery to make sure the drill has power.
다른 2명이 해당 안내서를 완성하였습니다.
Alex Cominos
회원 가입일: 02/14/19
376 평판
안내서 2개 작성하였습니다
USF Tampa, Team S1-G2, Leahy Spring 2019 USF Tampa, Team S1-G2, Leahy Spring 2019 회원
USFT-LEAHY-S19S1G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 5
전체 시간: 233
