소개
A damaged housing assembly will impede the users ability to properly insert the battery and undermines the drills durability in harsh working environments. Switching out the drill’s housing assembly requires a Hex 2.0 Screwdriver to remove the seven M3 X 14mm screws.
필요한 것
Eject the battery from the drill.
Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
To reassemble your device, follow these instructions in reverse order. Also reinsert the battery to make sure the drill has power.
다른 2명이 해당 안내서를 완성하였습니다.
