주요 콘텐츠로 건너뛰기
Ridgid R86008 Gearbox Replacement
필요한 것
  1. Ridgid R86008 Gearbox Replacement, Gearbox: 1 단계, 이미지 1/1
    • Before you begin make sure battery is removed from drill.
    • Loosen the four 13mm T10 Torx screws from the back of the drill and remove cap.
  2. Ridgid R86008 Gearbox Replacement: 2 단계, 이미지 1/1
    • Remove the two 25mm T10 Torx screws from the front of the drill.
  3. Ridgid R86008 Gearbox Replacement: 3 단계, 이미지 1/1
    • Remove the remaining 13mm T10 Torx screws and pull apart drill case.
  4. Ridgid R86008 Gearbox Replacement: 4 단계, 이미지 1/1
    • Identify gearbox.
  5. Ridgid R86008 Gearbox Replacement: 5 단계, 이미지 1/3 Ridgid R86008 Gearbox Replacement: 5 단계, 이미지 2/3 Ridgid R86008 Gearbox Replacement: 5 단계, 이미지 3/3
    • Using a PH1 screwdriver, remove the four 13mm PH screws from the back of the gearbox.
    • It may be easier to unscrew the screws by separating the front end of the drill from the rest of the drill.
  6. Ridgid R86008 Gearbox Replacement: 6 단계, 이미지 1/1
    • Pull apart gearbox.
결론
Lauren Dierkop
회원 가입일: 01/22/19
183 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 545
