소개
Soldering is required for some of the steps in this guide. Refer to the iFixit guide on Soldering if you need help learning how to solder. This replacement guide requires dealing with grease, make sure that you are wearing clothes that can get dirty and you are working on a surface that can get dirty.
필요한 것
Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
Rotate the casing until it fits onto the housing with no gaps between it and the clear cover.
다른 2명이 해당 안내서를 완성하였습니다.
