소개
This guide is to show how to open the Ring Doorbell to replace the battery. This is only for the 1st gen ring doorbells as newer versions do not have a battery and require full time power.
필요한 것
Two Lithium polymer batteries are connected back to back and in parallel to the regulator. The batteries are rated at 9.47w @ 3.75v each.
When you are satisfied that the battery is properly installed, the new battery should have enough charge that you will see at least one of several LED's light up. You can then close up. But if not, charge the unit via USB to see if the LED's are functioning. If not, check the battery connection.
다른 33명이 해당 안내서를 완성하였습니다.
댓글 59개
This is one of the few products that it's rarely if ever necessary to replace a battery in, as the warranty will cover a rapidly draining or not-charging battery. I'm glad you didn't tear down your chime, too! ;)
disagree. my battery went.
ralph -
Without a doubt there is a fault with the batteries on these 2020 5UM5E5 models. I’ve just had to replace the battery in mine. Bought from here.
Where can the battery be purchased?
https://www.amazon.com/dp/B0B191PVH7?psc...
just got it, its like OEM
ralph -
