주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ring Outdoor Security Cam Speakers Replacement
필요한 것
  1. Ring Outdoor Security Cam Speakers Replacement, Speakers: 1 단계, 이미지 1개 중 1개
    • Remove the six 6 mm Phillips #00 screws from the back on the device.
  2. Ring Outdoor Security Cam Speakers Replacement: 2 단계, 이미지 1개 중 1개
    • Pry off the aluminum plate using a plastic opening tool.
  3. Ring Outdoor Security Cam Speakers Replacement: 3 단계, 이미지 1개 중 1개
    • Use an opening tool to pry the back plate off of the device.
  4. Ring Outdoor Security Cam Speakers Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the battery power leads using a plastic opening tool.
  5. Ring Outdoor Security Cam Speakers Replacement: 5 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
  6. Ring Outdoor Security Cam Speakers Replacement: 6 단계, 이미지 1개 중 1개
    • Disconnect the ribbon cable carefully at the bottom of the device.
    • Remove the 3 silver 6 mm Phillips #00 screws from the motherboard.
  7. Ring Outdoor Security Cam Speakers Replacement: 7 단계, 이미지 1개 중 1개
    • Pull the top of the motherboard up and out of the device.
  8. Ring Outdoor Security Cam Speakers Replacement: 8 단계, 이미지 2개 중 1개 Ring Outdoor Security Cam Speakers Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the silver 5vmm Phillips #00 screw, and the two 10mm Phillips #00 from the next circuit board.
    • Remove the 3 plastic spacers on the device.
  9. Ring Outdoor Security Cam Speakers Replacement: 9 단계, 이미지 3개 중 1개 Ring Outdoor Security Cam Speakers Replacement: 9 단계, 이미지 3개 중 2개 Ring Outdoor Security Cam Speakers Replacement: 9 단계, 이미지 3개 중 3개
    • Pry the motherboard out with a plastic opening tool.
    • Flip the device over and then carefully press on the camera lens to remove the camera and the attached mother board from the device.
  10. Ring Outdoor Security Cam Speakers Replacement: 10 단계, 이미지 2개 중 1개 Ring Outdoor Security Cam Speakers Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the six silver 4.5 mm Phillips #00 screws holding the daughterboard into the device.
    • Then use the plastic prying tool to remove the final daughterboard and attached microphone
  11. Ring Outdoor Security Cam Speakers Replacement: 11 단계, 이미지 1개 중 1개
    • Using the plastic prying tool pop out the speakers on the back of the daughterboard.
결론
작성자
3다른 기여자 명과 함께
WilliamB22
회원 가입일: 09/13/23
968 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 19
전체 시간: 327
