주요 콘텐츠로 건너뛰기
Ring Spotlight Cam Battery The Mounting Bracket Replacement
필요한 것
  1. Ring Spotlight Cam Battery The Mounting Bracket  Replacement, The Mounting Bracket: 1 단계, 이미지 1/1
    • Place Mounting Bracket with lower elevation facing towards you.
  2. Ring Spotlight Cam Battery The Mounting Bracket  Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to unscrew the single bracket screw.
  3. Ring Spotlight Cam Battery The Mounting Bracket  Replacement: 3 단계, 이미지 1/1
    • Hold two corners from the middle of bracket and stretch outward.
  4. Ring Spotlight Cam Battery The Mounting Bracket  Replacement: 4 단계, 이미지 1/1
    • Slide bracket upwards.
결론
Smoo Rena
회원 가입일: 01/17/19
222 평판
안내서 3개 작성하였습니다
댓글 한 개
I have lost the single bracket screw. Where can I get a replacement?
Rick Burgess - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 17
전체 시간: 2,746
