주요 콘텐츠로 건너뛰기
Ring Stick Up Cam Speakers Replacement
필요한 것
  1. Ring Stick Up Cam Speakers Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the six 6mm Phillips #00 screws from the back of the device.
  2. Ring Stick Up Cam Speakers Replacement: 2 단계, 이미지 1/1
    • Pry off the aluminum plate using a plastic opening tool.
  3. Ring Stick Up Cam Speakers Replacement: 3 단계, 이미지 1/1
    • Remove the two 6mm Phillips #00 screws that were under the aluminum plate.
  4. Ring Stick Up Cam Speakers Replacement: 4 단계, 이미지 1/1
    • Pry off the back cover using a plastic opening tool.
  5. Ring Stick Up Cam Speakers Replacement: 5 단계, 이미지 1/1
    • Disconnect the battery power leads using a plastic opening tool.
  6. Ring Stick Up Cam Speakers Replacement: 6 단계, 이미지 1/1
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
  7. Ring Stick Up Cam Speakers Replacement, Camera: 7 단계, 이미지 1/1
    • Remove the three silver 6mm Phillips #00 screws holding the motherboard in the device.
  8. Ring Stick Up Cam Speakers Replacement: 8 단계, 이미지 1/1
    • Disconnect the ribbon connector shown in the photo.
  9. Ring Stick Up Cam Speakers Replacement: 9 단계, 이미지 1/1
    • Remove the motherboard from the device by hand.
  10. Ring Stick Up Cam Speakers Replacement: 10 단계, 이미지 1/1
    • Remove the two black 5mm Phillips #00 screws holding the camera board into the device.
    • Remove the single silver 10mm Phillips #00 screw holding the camera board into the device.
  11. Ring Stick Up Cam Speakers Replacement: 11 단계, 이미지 1/1
    • Remove the three plastic spacers shown in the photo by hand.
  12. Ring Stick Up Cam Speakers Replacement: 12 단계, 이미지 1/1
    • Carefully disconnect the camera board from the daughterboard by sliding a plastic opening tool between the camera board and the daughterboard.
  13. Ring Stick Up Cam Speakers Replacement: 13 단계, 이미지 1/1
    • Lift the camera board out of the housing using your hand.
  14. Ring Stick Up Cam Speakers Replacement, Microphone: 14 단계, 이미지 1/1
    • Remove the six silver 4.5mm Phillips #00 screws holding the daughterboard into the device.
  15. Ring Stick Up Cam Speakers Replacement: 15 단계, 이미지 1/1
    • Use a plastic opening tool to carefully pry the microphone from the housing.
  16. Ring Stick Up Cam Speakers Replacement: 16 단계, 이미지 1/1
    • Use your hands to remove the daughterboard containing the microphone from the housing.
  17. Ring Stick Up Cam Speakers Replacement, Speakers: 17 단계, 이미지 1/1
    • Using a plastic opening tool, remove both of the speakers.
결론
Chunyue Liu
회원 가입일: 02/06/19
273 평판
안내서 2개 작성하였습니다
UC Davis, Team S18-G3, Lore Winter 2019 UC Davis, Team S18-G3, Lore Winter 2019 회원
UCD-LORE-W19S18G3
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 15
전체 시간: 1,080
