주요 콘텐츠로 건너뛰기
Ring Video Battery and Wi-Fi Antenna Replacement.
  1. Ring Video Battery and Wi-Fi Antenna Replacement., Battery and Wi-Fi antenna: 1 단계, 이미지 1개 중 1개
    • Battery made of 2 units and a controller card with a 5-wire output. This battery can possibly be replaced by another one of the same final voltage, either by a parallel arrangement or by a direct connection of a unit.
    • The final amperage doesn´t need to be the same as the original battery.
    • The shape of the new battery doesn´t need to be the same either, since it can be placed externally just by inserting the cables.
  2. Ring Video Battery and Wi-Fi Antenna Replacement.: 2 단계, 이미지 1개 중 1개
    • Both options, using the controller card to facilitate the connection to the main motherboard, so it can recognize the power source.
  3. Ring Video Battery and Wi-Fi Antenna Replacement.: 3 단계, 이미지 1개 중 1개
    • The main motherboard with antenna card, and the chance of upgrading it with a generic antenna, improving reception and transmission.
결론
To reassemble your device, follow these instructions in reverse order
다음 번역가들에게 특별히 감사 드립니다:
es en
100%
Penny님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
AZUL BOCANDREA
회원 가입일: 01/14/21
97 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 40
전체 시간: 1,263
