주요 콘텐츠로 건너뛰기
Ring Video Doorbell Speakers Replacement
필요한 것
  1. Ring Video Doorbell  Speakers Replacement, Motherboard: 1 단계, 이미지 1/3 Ring Video Doorbell  Speakers Replacement, Motherboard: 1 단계, 이미지 2/3 Ring Video Doorbell  Speakers Replacement, Motherboard: 1 단계, 이미지 3/3
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminium plate using the Plastic Opening Tool(s).
    • Remove the 2 1 mm screws using the PH00 Phillips Screwdriver.
  2. Ring Video Doorbell  Speakers Replacement: 2 단계, 이미지 1/3 Ring Video Doorbell  Speakers Replacement: 2 단계, 이미지 2/3 Ring Video Doorbell  Speakers Replacement: 2 단계, 이미지 3/3
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
  3. Ring Video Doorbell  Speakers Replacement: 3 단계, 이미지 1/3 Ring Video Doorbell  Speakers Replacement: 3 단계, 이미지 2/3 Ring Video Doorbell  Speakers Replacement: 3 단계, 이미지 3/3
    • Unscrew the 9 1 mm screwdrivers using a PH00 Phillips Screwdriver.
    • Carefully detach the motherboard, from the housing unit using your hands.
  4. Ring Video Doorbell  Speakers Replacement: 4 단계, 이미지 1/2 Ring Video Doorbell  Speakers Replacement: 4 단계, 이미지 2/2
    • Detach the upper part of the motherboard from the bottom, using your hands.
  5. Ring Video Doorbell  Speakers Replacement, Speakers: 5 단계, 이미지 1/1
    • Speakers are two small rectangles located above the button of the doorbell.
  6. Ring Video Doorbell  Speakers Replacement: 6 단계, 이미지 1/1
    • To remove the speakers pry each one out carefully with a plastic opening tool.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Oscar Pascual-Diego
회원 가입일: 02/20/18
112 평판
안내서 1개 작성함
USF Tampa, Team S11-G5, Cheng Spring 2018 USF Tampa, Team S11-G5, Cheng Spring 2018 회원
USFT-CHENG-S18S11G5
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
Where does one get replacement speakers for the 88RG000FC100 ring doorbell?
Jeffrey Lang - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 20
30일 전: 67
전체 시간: 4,381
