주요 콘텐츠로 건너뛰기
Ring Video Doorbell Battery Replacement
필요한 것
  1. Ring Video Doorbell Battery Replacement, Battery: 1 단계, 이미지 1/3 Ring Video Doorbell Battery Replacement, Battery: 1 단계, 이미지 2/3 Ring Video Doorbell Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminium plate using the Plastic Opening Tool(s).
    • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
  2. Ring Video Doorbell Battery Replacement: 2 단계, 이미지 1/3 Ring Video Doorbell Battery Replacement: 2 단계, 이미지 2/3 Ring Video Doorbell Battery Replacement: 2 단계, 이미지 3/3
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Do NOT lift the case of all the way, there is still a cable connecting the two pieces.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Abdulrahman
회원 가입일: 02/20/18
685 평판
안내서 3개 작성하였습니다
USF Tampa, Team S11-G5, Cheng Spring 2018 USF Tampa, Team S11-G5, Cheng Spring 2018 회원
USFT-CHENG-S18S11G5
3 회원들
안내서 10개 작성하였습니다
댓글 4개
Where do I get a replacement battery?
William Price - 답글
I had an issue where the battery would not charge the light when I was trying to charge the battery flashed bue quickly, I removed the battery and found that the connector was corroded after cleaning it and making sure it was connected correctly the battery then took a full charge and now the bell functions as intended once again.
P.S thanks for the guide :)
David Haras - 답글
Who should the complete unit be sent to for checkup and repairs as it does not work
d.rayyan - 답글
can it be sent to the manufacturers for a replacement
d.rayyan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 19
7일 전: 114
30일 전: 482
전체 시간: 9,883
