소개
This guide will give detailed steps on how to replace the capacitor in the Ring Video Doorbell Pro.
필요한 것
Start by using the star-shaped end of the included Ring screwdriver to take out the 5 mm screw on the bottom of the device.
The next step is to remove the last four connections holding the motherboard in place.
To reassemble your device, insert the new capacitor and follow these instructions in reverse order.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 8개
where can I buy the replacement capacitor please or is it a case of buying a standard and making up the lead?
is that a battery right next to it? why didn’t you pull/mention that also?
I have the ring pro. What is the battery specification and what is the capacitor specification? If I going to all that work I need the replacement parts on hand.
The capacitor is a 470 uF/ 50 VDC electrolytic capacitor.
Battery is 350 mAh 3.7 volt Li 602030.
602030 battery listing: https://www.aliexpress.com/item/33029703...
tmiller -
