주요 콘텐츠로 건너뛰기
Rival 16131 Toaster bread grabber spring replacement
필요한 것
  1. Rival 16131 Toaster bread grabber spring replacement, Shell: 1 단계, 이미지 1/2 Rival 16131 Toaster bread grabber spring replacement, Shell: 1 단계, 이미지 2/2
    • Make sure the toaster is unplugged before dissembling.
    • Turn the toaster over and remove the rubber bumper feet.
  2. Rival 16131 Toaster bread grabber spring replacement: 2 단계, 이미지 1/2 Rival 16131 Toaster bread grabber spring replacement: 2 단계, 이미지 2/2
    • Use a Phillips #2 screwdriver to remove four 12 mm screws at the base of the toaster shell.
  3. Rival 16131 Toaster bread grabber spring replacement: 3 단계, 이미지 1/3 Rival 16131 Toaster bread grabber spring replacement: 3 단계, 이미지 2/3 Rival 16131 Toaster bread grabber spring replacement: 3 단계, 이미지 3/3
    • With the dial facing you, push the toaster base up and away until the base is just over the lip of the shell. This will disconnect the browning dial from the rest of the toaster.
    • When reassembling the toaster, make sure that the back of the dial lines up with the slot, both in position and orientation (the dial and slot are not perfect circles - they have a notch).
    • The only object holding the shell onto the toaster now is the grey part of the lever.
  4. Rival 16131 Toaster bread grabber spring replacement: 4 단계, 이미지 1/1
    • Reach into the shell and grab the back white part of the lever.
    • Hold the grey lever with both your index finger and middle finger. Next, pull it.
    • Pulling too hard will break the mechanism that holds the grey handle onto the white lever.
    • Remove the shell.
  5. Rival 16131 Toaster bread grabber spring replacement, Bread Grabber Springs: 5 단계, 이미지 1/1
    • Locate the black, diamond shaped spring behind the white lever bracket.
  6. Rival 16131 Toaster bread grabber spring replacement: 6 단계, 이미지 1/1
    • To remove the spring, use the tweezers to push the bottom edge of the spring out and around the metal bracket that keeps the springs in place.
    • Repeat this for the other side.
  7. Rival 16131 Toaster bread grabber spring replacement: 7 단계, 이미지 1/1
    • Pulling the bottom of the spring out, lift the left circle up over the metal bracket that extends out from the bread grabbers.
    • Bring the right circle out, down, and around the bracket the extends out from the shelf that the toast would sits on.
    • Remove the right circle.
  8. Rival 16131 Toaster bread grabber spring replacement: 8 단계, 이미지 1/1
    • Make sure that all the angles are similar to the other metal spring.
    • If not, then bend the broken spring to the angles of the correct spring.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Grant Haug
회원 가입일: 09/26/12
148 평판
안내서 4개 작성하였습니다
Cal Poly, Team 2-8, Propen Fall 2012 Cal Poly, Team 2-8, Propen Fall 2012 회원
CPSU-PROPEN-F12S2G8
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 22
전체 시간: 3,652
