소개
The Rival single cup coffee maker has water tubes that a prone to leaking. If boiling water runs through the tubes for too long, they can come loose and leak water. The tubes are held in by a simple spring that can be loosened by hand.
필요한 것
Remove the 8mm Phillips screw that attaches the power button to the inside of the coffee maker.
Remove the two rubber water tubes from the heating element by firmly pulling each at a 90 degree angle from the socket.
거의 끝나갑니다!
결론
