주요 콘텐츠로 건너뛰기
Rival Crock Pot 3120 Disassembly
필요한 것
추천 문서
  1. Rival Crock Pot 3120 Disassembly, Rival Crock Pot 3120 Disassembly: 1 단계, 이미지 1/1
    • Remove the lid from the crockpot and turn the device over, so that the bottom faces up.
  2. Rival Crock Pot 3120 Disassembly: 2 단계, 이미지 1/2 Rival Crock Pot 3120 Disassembly: 2 단계, 이미지 2/2
    • Use your fingers to remove the rubber end cap from the bolt on the bottom of the device.
  3. Rival Crock Pot 3120 Disassembly: 3 단계, 이미지 1/2 Rival Crock Pot 3120 Disassembly: 3 단계, 이미지 2/2
    • Using a 10mm wrench, remove the metal nut on the bottom of the device.
    • If the bolt connected to the nut appeared to fall into the device this is not an issue. It is connected to a metal bar within the device, so it cannot be lost.
  4. Rival Crock Pot 3120 Disassembly: 4 단계, 이미지 1/2 Rival Crock Pot 3120 Disassembly: 4 단계, 이미지 2/2
    • Using your hands, pull the plastic dial off the side of the device.
  5. Rival Crock Pot 3120 Disassembly: 5 단계, 이미지 1/3 Rival Crock Pot 3120 Disassembly: 5 단계, 이미지 2/3 Rival Crock Pot 3120 Disassembly: 5 단계, 이미지 3/3
    • Remove the nut behind the dial using a 16mm wrench.
    • Once the nut has been loosened you can finish unscrewing it with your hand.
  6. Rival Crock Pot 3120 Disassembly: 6 단계, 이미지 1/3 Rival Crock Pot 3120 Disassembly: 6 단계, 이미지 2/3 Rival Crock Pot 3120 Disassembly: 6 단계, 이미지 3/3
    • Remove the bottom panel using your hands.
  7. Rival Crock Pot 3120 Disassembly: 7 단계, 이미지 1/3 Rival Crock Pot 3120 Disassembly: 7 단계, 이미지 2/3 Rival Crock Pot 3120 Disassembly: 7 단계, 이미지 3/3
    • Slide the power cord out of its slot in the metal casing.
  8. Rival Crock Pot 3120 Disassembly: 8 단계, 이미지 1/2 Rival Crock Pot 3120 Disassembly: 8 단계, 이미지 2/2
    • Pull the rotary switch out from inside the metal casing.
  9. Rival Crock Pot 3120 Disassembly: 9 단계, 이미지 1/3 Rival Crock Pot 3120 Disassembly: 9 단계, 이미지 2/3 Rival Crock Pot 3120 Disassembly: 9 단계, 이미지 3/3
    • Slide the metal casing up and away from the internal components of the device.
  10. Rival Crock Pot 3120 Disassembly: 10 단계, 이미지 1/3 Rival Crock Pot 3120 Disassembly: 10 단계, 이미지 2/3 Rival Crock Pot 3120 Disassembly: 10 단계, 이미지 3/3
    • You have now successfully disassembled your device. From here you can troubleshoot or replace any specific parts.
결론
첨부 문서
Cole J. Morrel
회원 가입일: 09/14/22
181 평판
안내서 1개 작성함
댓글 4개
Reassembly is difficult, the bolt on the bottom is too short!
Johnb - 답글
Bolt is way too short to reassemble this thing and I'm not strong enough to bend the wire bail no matter how I try to do it. Never should have taken the thing apart.
Bob Hodge - 답글
It has been quite a long time since I went through this process but I seem to remember wrapping the threaded part of the bot in dental floss to use as a guide and threaded it through the hole with the crockpot propped up, upright so gravity would aid in assembly (some tire chocks on their sides would work, I think). It took some patience or perhaps stubbornness? But that's how I got it reassembled. I had a really hard time getting the bolt centered and the wire bail part vertical, which made the bolt seem impossibly short, before I tried this approach.
D. Marie Olsen Zito -
The bolt is definitely too short. I was taking it apart to clean it up- had I known, I wouldn't have bothered. I did bend the wire and tied some thread to the bolt- I was determined to not let it get the best of me.
Those heating wires that wrap around the pot are so thin, I was worried about breaking one. When I got it out back together I put some water in it and turn it on low- it was still working.
John Kershisnik - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 17
30일 전: 64
전체 시간: 1,228
