소개
This guide will help you remove the motor and requires the uses of a soldering iron. Check out this soldering guide for help if you don't know how to solder.
Twist the plastic lid counterclockwise to unlock it.
Lift the lid to remove it from the container.
Use a soldering kit to remove solder from the circuit board for the red wire.
Follow this soldering guide if you need extra help!
다른 3명이 해당 안내서를 완성하였습니다.
