주요 콘텐츠로 건너뛰기
Rival Mini Chopper MC-67BL Turning Gears Replacement
필요한 것
  1. Rival Mini Chopper MC-67BL Turning Gears Replacement, Turning Gears: 1 단계, 이미지 1/2 Rival Mini Chopper MC-67BL Turning Gears Replacement, Turning Gears: 1 단계, 이미지 2/2
    • Twist the plastic lid counterclockwise to unlock it.
    • Lift the lid to remove it from the container.
  2. Rival Mini Chopper MC-67BL Turning Gears Replacement: 2 단계, 이미지 1/1
    • Carefully remove the blade from the container.
    • For reassembly, the teeth on the metal shaft line up with slots on the inside of the plastic hole.
  3. Rival Mini Chopper MC-67BL Turning Gears Replacement: 3 단계, 이미지 1/1
    • With your hand, twist the container counter-clockwise until it unlocks from the base. Remove the container by lifting it straight up.
  4. Rival Mini Chopper MC-67BL Turning Gears Replacement: 4 단계, 이미지 1/1
    • Use your fingers to pry out the two rubber feet from the bottom cover of the base.
    • The two feet furthest from the button tower contain screws. The other two feet do not.
  5. Rival Mini Chopper MC-67BL Turning Gears Replacement: 5 단계, 이미지 1/2 Rival Mini Chopper MC-67BL Turning Gears Replacement: 5 단계, 이미지 2/2
    • Use the Phillips #2 screwdriver to unscrew the two 12.7-mm screws underneath the rubber feet.
    • Use the same screwdriver to unscrew the 15.88-mm screw from the back of the chopper.
  6. Rival Mini Chopper MC-67BL Turning Gears Replacement: 6 단계, 이미지 1/1
    • Firmly lift the bottom cover off of the base.
  7. Rival Mini Chopper MC-67BL Turning Gears Replacement: 7 단계, 이미지 1/1
    • Remove the smaller white gear by lifting it up with your hand.
  8. Rival Mini Chopper MC-67BL Turning Gears Replacement: 8 단계, 이미지 1/3 Rival Mini Chopper MC-67BL Turning Gears Replacement: 8 단계, 이미지 2/3 Rival Mini Chopper MC-67BL Turning Gears Replacement: 8 단계, 이미지 3/3
    • Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base.
    • Grab the gear with your other hand and turn CLOCKWISE. Unlike most screws, the gear is reverse-threaded to allow the blade to spin.
    • Continue turning the gear until completely removed from the blade-shaft.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Roxanne
회원 가입일: 10/17/13
522 평판
안내서 4개 작성하였습니다
Cal Poly, Team 4-29, Amido Fall 2013 Cal Poly, Team 4-29, Amido Fall 2013 회원
CPSU-AMIDO-F13S4G29
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 805
