주요 콘텐츠로 건너뛰기
Rivet Replacement on Work Pants
필요한 것
  1. Rivet Replacement on Work Pants, Decide how you will make the repair: 1 단계, 이미지 2개 중 1개 Rivet Replacement on Work Pants, Decide how you will make the repair: 1 단계, 이미지 2개 중 2개
    • If you have access to a hand press and rivet dies, proceed with Steps 2 - 5.
    • If you don't have access to a hand press and rivet dies, skip to Step 6 to complete this repair with a hammer.
  2. Rivet Replacement on Work Pants, Prepare the dies: 2 단계, 이미지 3개 중 1개 Rivet Replacement on Work Pants, Prepare the dies: 2 단계, 이미지 3개 중 2개 Rivet Replacement on Work Pants, Prepare the dies: 2 단계, 이미지 3개 중 3개
    • Check that the back of the rivet (nail) fits into the nail die. Put the rivet nail aside and place the nail die into the bottom slot of the hand press.
    • Snap the front of the rivet (head) into the head die. The rivet head should stay securely in the die.
    • To insert the head die into the press:
    • Use your fingers, a screwdriver, or a hex key, as needed, to unscrew the tightening mechanism on the side of the press near the top die fitting.
    • Insert the die upward and hold it in place.
    • Tighten the tightening mechanism.
  3. Rivet Replacement on Work Pants, Place the garment onto the press: 3 단계, 이미지 3개 중 1개 Rivet Replacement on Work Pants, Place the garment onto the press: 3 단계, 이미지 3개 중 2개 Rivet Replacement on Work Pants, Place the garment onto the press: 3 단계, 이미지 3개 중 3개
    • Place the rivet nail into the hole left by the previous rivet from the backside.
    • Bring the garment to the hand press and center the rivet nail into the bottom die.
    • Push down the spring of the nail die to keep the rivet nail in place, flush with the garment and visible through the hole.
    • Hold all the pieces in place with your non-dominant hand.
  4. Rivet Replacement on Work Pants, Set the rivet and quality control: 4 단계, 이미지 3개 중 1개 Rivet Replacement on Work Pants, Set the rivet and quality control: 4 단계, 이미지 3개 중 2개 Rivet Replacement on Work Pants, Set the rivet and quality control: 4 단계, 이미지 3개 중 3개
    • Pull down firmly on the press handle to set the rivet.
    • Check that the rivet is firmly set:
    • Pull on each side of the rivet to test that it's secure.
    • The front and back pieces should be parallel to each other, not set at an angle.
    • The rivet shouldn't be able to spin.
    • If the rivet spins, reattach the head to the head die, line up the nail piece with the nail die, and pull again firmly on the hand press.
  5. Rivet Replacement on Work Pants, Troubleshooting: 5 단계, 이미지 2개 중 1개 Rivet Replacement on Work Pants, Troubleshooting: 5 단계, 이미지 2개 중 2개
    • FABRIC DAMAGE: If the fabric surrounding the rivet hole is damaged, a reinforcement patch needs to be sewn before setting a new rivet.
    • HAND PRESS NOT AVAILABLE: It's possible to set rivets without using a hand press. Continue with Steps 6 - 8.
  6. Rivet Replacement on Work Pants, Partially fasten the rivet: 6 단계, 이미지 2개 중 1개 Rivet Replacement on Work Pants, Partially fasten the rivet: 6 단계, 이미지 2개 중 2개
    • Place the head and nail pieces of the rivet on either side of the hole left by the original rivet.
    • Use your fingers or needle nose pliers to squeeze both sides of the rivet together.
    • This pressure should be enough to partially fasten the rivet and keep the pieces in place without being held.
  7. Rivet Replacement on Work Pants, Hammer the rivet: 7 단계, 이미지 2개 중 1개 Rivet Replacement on Work Pants, Hammer the rivet: 7 단계, 이미지 2개 중 2개
    • Lay the garment on a stone block, piece of scrap wood, or other hard surface, with the rivet head facing down.
    • Use needle nose pliers to hold to rivet nail in place, making sure the head and nail pieces are still aligned.
    • Gently tap the back of the rivet with a hammer until the rivet is fastened enough to stay aligned without the pliers.
    • Remove the pliers, then hold the fabric around the rivet in place and continue to carefully hammer the rivet until it's securely fastened.
  8. Rivet Replacement on Work Pants, Quality control: 8 단계, 이미지 2개 중 1개 Rivet Replacement on Work Pants, Quality control: 8 단계, 이미지 2개 중 2개
    • If the rivet spins, repeat the hammering process until it's fully secure.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Zach Mueller
회원 가입일: 02/23/23
1,720 평판
안내서 9개를 작성함
Patagonia Patagonia 회원
Community
17 회원들
안내서 168개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 32
지난 30일: 191
전체 시간: 1,304
