주요 콘텐츠로 건너뛰기
Roborock Q5 Max Plus Battery Replacement
필요한 것
  1. Roborock Q5 Max Plus Battery Replacement, Side Brush: 1 단계, 이미지 2개 중 1개 Roborock Q5 Max Plus Battery Replacement, Side Brush: 1 단계, 이미지 2개 중 2개
    • Carefully flip the Roborock upside down on a soft surface (e.g., towel) to avoid scratches.
    • Turn off the vacuum using the main switch underneath.
  2. Roborock Q5 Max Plus Battery Replacement: 2 단계, 이미지 3개 중 1개 Roborock Q5 Max Plus Battery Replacement: 2 단계, 이미지 3개 중 2개 Roborock Q5 Max Plus Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Hold down the side brush with one hand to prevent it from moving.
    • Use a Phillips #1 screwdriver to remove the single screw securing the side brush.
    • Remove it from the base.
  3. Roborock Q5 Max Plus Battery Replacement, Bottom Panel: 3 단계, 이미지 2개 중 1개 Roborock Q5 Max Plus Battery Replacement, Bottom Panel: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove the eight 14 mm screws that secure the bottom shell.
  4. Roborock Q5 Max Plus Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Gently lift the the bottom shell up and off.
    • If you encounter resistance, double-check for any hidden screws that may have been overlooked.
  5. Roborock Q5 Max Plus Battery Replacement, Battery: 5 단계, 이미지 3개 중 1개 Roborock Q5 Max Plus Battery Replacement, Battery: 5 단계, 이미지 3개 중 2개 Roborock Q5 Max Plus Battery Replacement, Battery: 5 단계, 이미지 3개 중 3개
    • Carefully pry out the battery and remove it from its housing.
    • Don't fully remove it as its still connected to the vacuum.
  6. Roborock Q5 Max Plus Battery Replacement: 6 단계, 이미지 3개 중 1개 Roborock Q5 Max Plus Battery Replacement: 6 단계, 이미지 3개 중 2개 Roborock Q5 Max Plus Battery Replacement: 6 단계, 이미지 3개 중 3개
    • Carefully press on the side tab of the connector to release the latch, then pull the connector straight up and out of its port.
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
작성자
3다른 기여자 명과 함께
Fernando Rivera
회원 가입일: 02/19/25
408 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 8
지난 30일: 35
전체 시간: 296
