주요 콘텐츠로 건너뛰기
Roborock Q5 Pro: Laser Distance Sensor Replacement
필요한 것
  1. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the dustbin.: 1 단계, 이미지 3개 중 1개 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the dustbin.: 1 단계, 이미지 3개 중 2개 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the dustbin.: 1 단계, 이미지 3개 중 3개
    • Flip it on its head, then remove the dustbin.
  2. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bottom cover.: 2 단계, 이미지 2개 중 1개 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bottom cover.: 2 단계, 이미지 2개 중 2개
    • Remove the side brush using a PH2 screwdriver.
    • Remove the screws using a PH2 screwdriver.
    • Then, pull the bottom cover off.
  3. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the battery.: 3 단계, 이미지 3개 중 1개 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the battery.: 3 단계, 이미지 3개 중 2개 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the battery.: 3 단계, 이미지 3개 중 3개
    • Lift it up on the left.
    • Detach the connector by squeezing the release tab, then pull it out.
    • Do not simply yank the battery out. You will tear the connector off the motherboard.
  4. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bumper's lid.: 4 단계, 이미지 2개 중 1개 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bumper's lid.: 4 단계, 이미지 2개 중 2개
    • Remove the marked screws using a PH1 screwdriver.
    • Then simply lift the lid off.
  5. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bumper.: 5 단계, 이미지 2개 중 1개 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bumper.: 5 단계, 이미지 2개 중 2개
    • Flip the robot over.
    • Tilt the bumper forwards and move it upwards to remove it.
  6. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the side brush motor.: 6 단계, 이미지 1개 중 1개
    • Flip it back over.
    • Simply lift it out.
  7. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the chassis screws.: 7 단계, 이미지 1개 중 1개
    • Remove the marked screws using a PH2 screwdriver.
  8. Roborock Q5 Pro: Laser Distance Sensor Replacement, Latches.: 8 단계, 이미지 3개 중 1개 Roborock Q5 Pro: Laser Distance Sensor Replacement, Latches.: 8 단계, 이미지 3개 중 2개 Roborock Q5 Pro: Laser Distance Sensor Replacement, Latches.: 8 단계, 이미지 3개 중 3개
    • The chassis will still be held together by a couple latches on the back.
    • Use a prying tool to get these apart before taking it apart.
  9. Roborock Q5 Pro: Laser Distance Sensor Replacement, Take it apart!: 9 단계, 이미지 2개 중 1개 Roborock Q5 Pro: Laser Distance Sensor Replacement, Take it apart!: 9 단계, 이미지 2개 중 2개
    • Flip it over and simply pull the chassis halves apart.
  10. Roborock Q5 Pro: Laser Distance Sensor Replacement, Screeeeeeews.: 10 단계, 이미지 1개 중 1개
    • Here are the screws organised by steps and type.
    • Use this if needed as a reference during reassembly.
  11. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS cage.: 11 단계, 이미지 3개 중 1개 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS cage.: 11 단계, 이미지 3개 중 2개 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS cage.: 11 단계, 이미지 3개 중 3개
    • Then, remove it.
  12. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS.: 12 단계, 이미지 3개 중 1개 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS.: 12 단계, 이미지 3개 중 2개 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS.: 12 단계, 이미지 3개 중 3개
    • Lift the LDS towards the right, then disconnect the connector.
    • If you're replacing the LDS, simply insert the new one and reassemble your device.
  13. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the rubber band.: 13 단계, 이미지 3개 중 1개 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the rubber band.: 13 단계, 이미지 3개 중 2개 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the rubber band.: 13 단계, 이미지 3개 중 3개
    • Remove the rubber band using some tweezers, forceps or your fingers.
    • Make sure to clean it. This one was quite dirty, which was causing the motor to seize.
    • Your robot may have a different iteration of the LDS, which has a cover over the rubber band section. In that case, please check: Roborock Q Revo: Laser Distance Sensor Replacement and skip to step 12.
  14. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the motor.: 14 단계, 이미지 3개 중 1개 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the motor.: 14 단계, 이미지 3개 중 2개 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the motor.: 14 단계, 이미지 3개 중 3개
    • Before removing the motor, flip it over and check whether it has a connector or is soldered directly onto the PCBA.
    • Remove the screws.
    • Now you can remove and replace the motor.
    • Your robot may have a different iteration of the LDS, which needs it's driving wheel removed before you can remove the screws. In that case, please check: Roborock Q Revo: Laser Distance Sensor Replacement and skip to step 12.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
DegenFixer
회원 가입일: 09/18/24
5,081 평판
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 28
지난 7일: 118
지난 30일: 456
전체 시간: 4,659
